Introduction: Camp Stove
This is my take on the pop can camp stove. You should be able to use almost any liquid fuel, but choose what you put in it carefully, you wouldn't want to put something like gasoline in it. Also it has a removable pot holder that slips over it so that you don't have to make a separate one and carry around. It is thin and when empty can easily be slipped into a pocket to take with you on any camping trip.
Disclaimer: I am not responsible for what you do with this, used properly it should be relatively safe, but as anytime you deal with fire BE CAREFUL.
Step 1: Materials:
You will need these tools:
Razor knife/Exacto knife(any sharp knife could be used)
Awl(or some other sharp pointed object)
Hammer
You will also need two empty pop cans, I have three in the picture, because I was drinking out of one while i worked(very thirsty work you know).
Step 2: Cut the Bottoms Off
Start by cutting the first ones bottom off right at the part where the label ends and it curves downward.
Now, on the second one your going to want to cut about 3/4 of an inch above the bottom of the label.
Step 3: Now Hammer Out the Round Part
To make it hold the fuel better, use a hammer to flatten down the round part and make it bulge out the other way. Next, on the skinnier bottom use the awl to punch holes around the rim about half an inch apart, and about 10 of them in the center in any manner you want then hammer out the round part. I didn't put my holes in until after i had it bulged out, it should be done before.
Step 4: Put Them Together
Now, you need to set the smaller part inside the bigger one, and force it down, you might want to hold one side down and tap the other side with a hammer. Then use the hammer to tap the edge of the bigger can bottom, against the smaller.
Step 5: Some Finishing Touches
Now take the hammer, and make a dent in the bottom, thats as level as you can get it so that it will sit upright better. Also you may want to make an attached pot holder...just cut the top off of one of the cans you used, right at where it starts to slope inward. Now use either a can opener or a Razor knife to cut the top out. Next, your going to want to force it on top of your stove, i just stepped(not very hard of coarse) on mine, because its hard to get on. Now it probably tore(if it didn't it wont matter) in one spot, but thats ok, it will make it easier to take of and on. now take it off and make a line of holes just below the rim about 3/4 of an inch apart, just below that put more holes in between.
Step 6: Done!
Viola your finished. Now you just need to add fuel. You could use rubbing alcohol, or methylated spirits too, but thats up to you. All you have to do to fuel it is slowly(very slowly) pour your fuel of choice onto the top where the holes are. It will run down into the holes in the center, and what doesn't will run down into the holes at the edge.
Pocket-Sized Contest
15 Comments
13 years ago on Introduction
Great work! Acetone and it's byproducts are carcinogenic, especially the fumes if burnt in insufficient oxygen like this! Excellent, cancer causing stove!
Reply 13 years ago on Introduction
NOT!!! Where are you getting your information from? I hate pseudo science and half @$$ed praticioners of it. Acetone is not a carcinogene, matter of fact, it is a normal by product of metabolism. I guess your also one of the wackos that also thing C02 is a carcinogen.
Reply 2 years ago
It's CO as well. Sheesh engliext is baderer hair
Reply 2 years ago
What the hell have you been drinking in order to pee acetone?
Read up!
http://wonder.cdc.gov/wonder/prevguid/p0000467/p0000467.asp
Knowledge is power, misinformation is crap!!!
wow, i didn't know that. Thanks for warning me...but I don't see anywhere on the label where it mentions being a carcinogen.
Tip 2 years ago
Warning us about the initial WHUMP! And flash fireball would have been nice. Pretty nails maybe but the hair on my head can go to hell.
Like most people my initial reaction to a fireball like that is to immediately open my eyes as wide as possible and take in as much flame as I can till I can overpower that urge and I can engage my safety squints and if by some miracle of the diety of my choice I didn't toss the item that the fireball erupted from across the room and haven't set the house on fire I can tremble while I quickly scan the vicinity for anyone that saw the fireball and my shamefully weak performance as a man and if the frozen position they are in isn't enough I can always follow up with an nervous "did you see that?" But usually I'm just running around hoping my bare hands are enough to kill the flames on the curtains
6 years ago
do not use acetone i went to hospital after i tryed to a fire out
Reply 2 years ago
Sounds like you banged your head on something too. If your grasp of English grammar is anything to go by. And yes that initial WHUMP! From the vapors upon igniting the stuff can induce a heart attack.
2 years ago on Introduction
Erm... then why not call it (insert fuel name)stove instead of naming it for one of the fuels you shouldn't use? You can edit your instructable if not just copy the thing then make a new one without the bad name. Then delete this instructable? It's not like the view count for this instructable is helping you pull a bunch of tail. However if it is point me in its direction. But if I end up having to use knitting needles on my eyeballs I'm giving you a slap. Jesus just what was it I was reading to end with that line??? Acetone, now it all makes sense. Also give you cancer, and if you ask me keep an eye on your wallet.
A good basic design for the stove. I would recommend you stay away from acetone as a fuel, however. Denatured alcohol (methylated spirits on the other side of the pond) are your best bet. Burns clean and with much less smell than you are going to get with fingernail polish remover.
yeah, thats for sure lol. but thats all i had handy and it worked.
Acetone is not a carcinogen. We use tonnes of the stuff at work without issue. The worst it'll do is dry your skin by removing the natural oils.
If you're burning pure acetone it shouldn't smell (available at auto shops).
I would strongly suggest burning something less volatile though as acetone can be ignited from even static shock sparks! Beware the stuff. We have to have all our tanks grounded. The vapours are super easy to ignite.
Another good reason not to use acetone is it'll melt a lot of plastics on contact!
ic
try some ethyl rubbing alcohol, get the highest concentration and proof you can find.
