Acid Blackened Custom Hunting Knife
Intro: Acid Blackened Custom Hunting Knife
STEP 1: Cutting the Blade and Sourcing Steel
If you are looking for other cheap alternatives to buying proper tool steel, you can also use old circular saw blades, you can cut material out of old handsaws, you can restore and modify knives from flea markets and garage sales, or use any high carbon steel which can be heat treated. If you are looking for a more professional approach, I would suggest using O1 tool steel, which is what many professional knife kakers use. Surprisingly, you can order O1 tool steel through Amazon, and a 1/8x2x18 inch pieces of barstock would run you around $30. You should absolutely be able to make about 3 knifes with this size piece of steel, especially if you are just beggining knife making and starting with smaller knives.
STEP 2: Refining and Cleaning the Blade
STEP 3: Beveling
It took me around half an hour to bevel each side, and I was incredibly happy with the result. This type of jig, which there are literally hundreds of variations, is the most effective way to hand bevel a knife with phenomenal results.
STEP 4: Vinegar Blackening Solution
I hadn't done any research on how to blacken knifes using this technique, so it was very interesting experimenting with the different knife blades I had and seeing how quickly the results could change on an hourly basis. I heard about this technique from Mike Craughwell, the guy who had the TV show big giant swords, but other than that I did no research and was clueless as to how it would come out. My tips to all of you would be to experiment with it until you find the effect you like, not to keep in it to long otherwise all of the vinegar reacts with the knife until it all dries out and crystallizes (this was very unexpected), and lastly not to keep any other metal items around it because it causes them to rust incredibly fast (again, I did no research so that was an interesting discovery). I also found it is necessary to oil the knife shortly after with a professional grade oil like ballistol or simply with WD40.
STEP 5: Making the Handle Scales + Shaping and Sanding
I wanted the knife to be a hidden tang knife, meaning that the metal handle part of the blade is entirely encased in the handle material, so the only metal shown on the knife is the blade. To achieve the look of a hidden tang I had to carve out a perfectly shaped area for the tang to sit inside of the handle.
Since this knife was only my first knife, and I was still learning and experimenting, I used wood from a pine 2 by 4, and cut that to size with a jigsaw. I really wanted a nice finish on the handle, so I spent hours and hours shaping the knife and sanding it all the way to a 240 grit until I couldn't see any noticeable sanding marks, and I additionally stained it with a medium color Varathane Early American. While shaping the knife I wanted a flare out palm swell for comfort but I also wanted the contours of the blade to match with the contours of the handle, which I think I achieved flawlessly. The handle feels so incredibly great in the hand and the palm swell makes it feel incredibly ergonomic. I also found it feels great in the hand regardless of whether I hold it normally, or the "opposite" way, with the palm swell by my index finger instead of my pinky. This sounds irrelevant, but I think it is quite important because it means I could use it comfortably to carve a stick into a point, or alternatively, to switch my grip and stab into something, and be able to support the knife by placing my thumb on the end of the palm swell. The ability to use any grip comfortably is crucial to the design because I can use the knife for delicate, controlled work such as simple carving or cutting leather and things of that nature as well as be able to use the knife for more crude work with an opposite grip to stab into and open sacks of animal feed and grain, or skin an animal. I purposefully designed the knife to be as practical as possible, with as many different uses as I could manage. Again, it seems arbitrary but the design of this knife provides it with the capability if being a bit of a workhorse as well as a controlled and more elegant and precise knife.
STEP 6: Final Thoughts
Thank you!
Brandon (16)
9 Comments
Kozz 7 years ago
Incredible work for a first knife, Brandon! Tell me what kind of glue did you use for the handle halves? Wood glue? Gorilla glue? Epoxy?
I've got two halves of a new oak handle cut for a machete, but am trying to figure out what kind of glue would be best. Of course it will ultimately be further shaped, sanded, sealed, stained and probably polyurethane.
SirCooksalot 7 years ago
Generally a two-part epoxy is the thing to use for securing knife handles and scales. Some custom makers get into the fancy industrial epoxies, but the majority seem to go with readily available epoxy options like Loctite, Gorilla, or Devcon. I've used Devcon 2-ton with great results. Get the 'regular' set time stuff, you don't want a 5-minute epoxy... I know people DO use 5-min epoxy, but the more experienced makers will tell you it's no good. The faster an epoxy sets up, the more brittle the bond- not good for a sub-zero day and a metal tool. For about $10, you can get Devcon 2-ton in two bottles (instead of the double syringe setup) which is easier to measure, pour, and store, and is enough for MANY projects.
Modern Rustic Workshop 7 years ago
Silverwraith 7 years ago
great channel, monthly builds, and great inspiration.
the knife looks fantastic, well done!
LeoWorks 7 years ago
pleblond 7 years ago
Very nice knife for a first attempt. Well done!
discostu956 7 years ago
Not at all! As I mentioned, I made sure to keep the edge of the blade very cool as I cut through the metal. I constantly submerged the blade in water as I was cutting it out, and payed extra attention so that the heat created from cutting it would destroy the heat treatment. Thanks for commenting!
