Introduction: "Acrylic" Name With RGB Led !!AMEZING!!
In the following section we are going to use an acrylic sheet and make design on it then we will scratch the design and the final output looks awesome with the RGB led strips
Step 1: WATCH THE VIDEO
Step 2: PARTS LIST
To make the following awesome looking name plate we need the following parts
1.Acrylic glass sheet
2.RGB led strip
3.RGB led strip controller
4.Regular knife much sharper or any mica sheet cutter
5.Box to place the acrylic sheet
6.Sketch pen
NOTE : The dimensions of the acrylic sheet depends upon what you are writing on it or drawing on it and the rgb led strip is usually comes with its controller so no need to buy another one
Step 3: SKETCH YOUR DESIGN
Once you are ready the]at what you are going make on the acrylic sheet. Start making it on the piece of acrylic with the sketch pen
Make sure don't draw too complicated sketch because you are going to scratch it in the next step.
Step 4: SCRATCH YOUR DESIGN
Once you have drawn your sketch with the help of a marker follow the outline of the sketch
and scratch slowly with the help of a sharp knife or a mica sheet cutter
make sure this process is time taking and if you have created any other scratch on the arcylic glass then those will be clearly visible while we use that
Step 5: CREATING THE BOX
After the completion of the scratch we can create a small housing for the beautiful lights
In my case i have used a cardboard peace and i have used some wood glue and tape to cover all the gaps
you can do the same or improve it by using a plastic box or a handmade wood box
you can see the construction of the box in the video above
Step 6: ADDING THE GLOW (RGB LED's)
now in the last step we can connect the led strips to the acrylic glass.
we can add the led at the bottom of acrylic glass so that those will not be visible at directly to the eyes
At the first use some hot glue and then gently place the led as shown in the video and follow this until you cover maximum of the acrylic glass is covered
now connect the wires from the controller to the led strip as red green blue for the three color and the black wire represent the ground
After all these steps make some small hole for the ir reciver and the dc jack for 12v power supply
AND THAT'S IT YOU ARE NOW READY WITH YOUR OWN ACRYLIC RGB LED NAME PLATE
Step 7: THANKS FOR WATCHING
VISIT MY YOUTUBE CHANNEL FOR MORE STUFFS BASED ON THE ELECTRONICS CIRCUITS AND ARDUINO UNO BASED PROJECTS AS WELL AS CREATIVE VIDEO SECTIONS AS SUCH THIS VIDEO
LINK TO MY YOUTUBE IS GIVEN AS
