Acrylic Penny Maze
Intro: Acrylic Penny Maze
STEP 1: Planning
Planning started the old-fashioned way, with pencil and paper.
I worked on squared paper, planning routes up and down through five layers. I exploited the squares' size to plan 20mm channels, allowing both one cent and one penny coins to be used in the maze.
I then scanned the sketches into PDF files, and used InkScape to "draw over" the PDFs, and save the digital versions as DXF files.
Don’t have a laser cutter?
Download the Ponoko ready SVG design file ("Acrylic Maze All Layers") and upload to the Ponoko site. Select 3mm thick x "P3" sized sheet of clear acrylic. Wait a couple of days and you’ll receive your custom cut acrylic pieces for the project in the post. From here, you’ll want to skip to step 3 and start assembling, as step 2 is all about cutting if you have a laser.
STEP 2: Cutting
The path sections of the maze were made from 3/16 inch clear acrylic, and the separating layers were cut from 1/8 inch clear acrylic.
The former was the closest available thickness that would allow the coins to move freely, the latter was the thinnest acrylic available, to keep the bulk of the maze down a little, and to stop coins falling at an odd angle and getting stuck.
I used an Epilog laser cutter, at the setting recommended by the operating manual for the materials.
If you want to cut your own, just choose the files from this step in the format that is suitable for your laser cutter.
Leave the protective film on the acrylic during cutting, to protect your exposed surfaces..
STEP 3: Assembly
I popped out the off-cuts, and peeled off the protective film before arranging the layers in order and bolting them together.
When I used Ponoko to make a maze, I decided not to use wing-nuts so that it was smoother thing to handle and less, well, wing-nutty.
A word of warning: if you are using my original files, check the bolt-hole alignment - as a result of them being basically hand-drawn, some of the holes needed a quick go with a dremel to round them off and line them up.
It is important that I held the layers together with bolts, rather than adhesive, because the square section in the lower layers is a trap - if your penny ends up in there, you have failed, and can only get your money back by dismantling the maze.
Cheat.
STEP 4: Does It Work?
Did it work?
Did it distract people around the office from their proper work?
Did it cause fascination and frustration in equal measure?
Did it distract Conker-X from his computer?
Yes!
This was a fun project - I need to think of an excuse to use laser cutters again!
31 Comments
aymanlee 8 years ago
Hello, what kind of screws do you use? Did you make a threaded hole for the screws?
Kiteman 8 years ago
They're 1/4 inch bolts with a matching wing-nut.
The holes are not threaded, they're just circles cut in each layer.
kracken42 10 years ago
This is incredible.
Kiteman 10 years ago
Thank you!
Fikjast Scott 10 years ago
Great work, I really like this.
Thank you!
mg0930mg 11 years ago
Kiteman 11 years ago
bricabracwizard 10 years ago
andrea biffi 10 years ago
blueangelical 10 years ago
I'm afraid I can't make another for sale (the laser cutter I used is in San Francisco, I am in the UK), but you are welcome to use the files to get one made by one of the growing number of online laser cutter services, such as Ponoko.
poofrabbit 11 years ago
