Introduction: Action Camera Handle Mount
I recently bought a $20 nock off of a GoPro and it didn't come with many mounts so today I'm going to create a handle to do water sports with. The tripod mount it came with isn't a normal one where you can screw a bolt in so I am modifying a design, I hope you enjoy
Step 1: Materials and Tools
For this you will need You will need
Some kind of small tripod mount
PVC Pipe
A drill bit to thin out the pipe and a drill
A heat gun or torch
Pliers
Heat resistant gloves
PVC Pipe
A heat gun or torch
Pliers
Step 2: Preparing the Pipe
Start by using the drill to thin The Pipe so it will stretch out and conform to the tripod mount when heated.
Step 3: Forming the Pipe and Tripod Mount
Use the heat gun or torch to heat the pipe until its soft and moldable. Stick the tripod mount in the hole and use pliers and gloves to press the soft pipe.
Step 4: Cut the Handle to Length
Find how long you want it to be and cut it.
Step 5: Add a Lanyard
Drill a small hole and stick a rope through. Tie it of to where it can tighten around either your wrist or a floating thing.
Step 6: Conclusion
This mount works great and it actually floats, the only problem is the camera turns out to not be very water proof. I hope you enjoyed please like subscribe and if you could vote for me. Thanks for reading
