Introduction: Adafruit Motor Shield & Funduino
Download our FREE Arduino Project Code
Attach Funduino and Motor Shield together.
Step 1: IDE
Open the Arduino IDE then click Tools / Board / Arduino Duemilanove w/ AT328
Step 2: Upload the Sketch
Upload the code below, make sure that you plug the USB cable and choose the right Serial Port.
Test the (2) DC motors to move Forward and Backward.
#include
int i;
// DC motor on M1
AF_DCMotor motor(1);
// DC motor on M2
AF_DCMotor motor2(2);
void setup() {
// Turn ON DC MOTOR #1
motor.setSpeed(200);
motor.run(RELEASE);
// TURN ON DC MOTOR #2
motor2.setSpeed(200);
motor2.run(RELEASE);
void loop() {
motor.run(FORWARD);
motor2.run(FORWARD);
for (i=0; i<255; i++) {
motor.setSpeed(i);
motor2.setSpeed(i);
delay(10);
motor.run(BACKWARD);
motor2.run(BACKWARD);
motor.setSpeed(i);
motor2.setSpeed(i);
delay(10);
// code ends here
Step 3: Bluetooth Module
You can also attach a Bluetooth module to control the motor using your Android phone.
Step 4: Upload Sketch for Bluetooth
/* Use your Android phone to control your motor FORWARD / REVERSE / LEFT / RIGHT
Upload code below.
#include
char val; // Variable to receive data from the serial port
// DC motor on M1
// DC motor on M2
int i;
void setup() {
Serial.begin(115200);
// turn on motor #1
motor.run(RELEASE);
// turn on motor #2
// Move FORWARD
void go_forward(){
motor.run(FORWARD);
motor.setSpeed(i);
motor2.setSpeed(i);
// Move REVERSE
void go_reverse(){
motor.setSpeed(i);
motor2.setSpeed(i);
// Move LEFT
void go_left(){
motor.run(FORWARD);
motor.setSpeed(i);
// Move RIGHT
void go_right(){
motor2.setSpeed(i);
// Read serial port and perform command
void performCommand() {
if (Serial.available()) {
val = Serial.read();
if (val == 'f') { // Forward
go_forward();
// } else if (val == 'z') { // Stop Forward
// stop_go_forward();
} else if (val == 'b') { // Reverse
go_reverse();
} else if (val == 'y') { // Stop Reverse
// stop_go_reverse();
} else if (val == 'l') { // Right
go_right();
} else if (val == 'r') { // Left
go_left();
// } else if (val == 't') { // Stop Car using Turbo function
// stop_car();
void loop() {
performCommand();
// code ends here
Step 5: Android App
Use the "Smart Home with Voice command" app to test your Bluetooth module.
Google PlayStore.
Step 6: WarBot
You may also want to build
