Adapt a Sledgehammer Head to Make a Big Boy Blacksmith Hammer.
9,335
62
9
Introduction: Adapt a Sledgehammer Head to Make a Big Boy Blacksmith Hammer.
Need a bigger hammer? I did. I kept buying hammers for blacksmithing and none of them seemed beefy enough for really whacking the heavy stuff. They were fine for normal work, just not for really pounding and moving a big bar of damascus I'm making. I have a sledgehammer, but most of the time I work alone in the forge, so can't use it.
I decided to take an old sledgehammer head and make a suitable big hammer. I could have just put a short handle on it, but it would have been too heavy (8lbs) and not the shape I wanted.
Materials:
Old sledgehammer head
handle, or suitable wood for handle
hammer wedge
Tools:
Angle grinder with metal cutting discs and sandpaper flap disc
sharpie
saw
sandpaper
hammer
Step 1: Outline Your Idea...
Get your old sledgehammer head and draw the shape you'd like with a sharpie. For my purposes, I wanted the main face to have a small flat disc area, then be rounded away. This means I could put a huge force (considering my puny arm) in a small area and use the rounded parts in various ways.
I drew a circle on the face the same size as my claw hammer head. This was centred so I could cut and sand away equally and evenly. The picture shows it after I'd cut some of the meat away, I got a bit carried away and forgot to take a photo before this.
On the rear side I wanted a 'cross pein', the second picture shows the hammer head on it's side with the first outline made. I then matched the key lines across the top and back so that I could exactly repeat the sides.
Step 2: Cut and Sand...
I used the cutting disc first and cut away the waste steel, making sure I didn't go over the sharpie marks.
Then I switched to the flap disc. I used 60 grit, because that's what I had. It moves steel incredibly well. I had no idea how well. Phew!
I was going to go up through the grits but the 60 did a lovely job, and in any case mine will be used for the initial whacking of very hot metal so a mirror finish wouldn't last long.
I gave a quick sanding to the top and left the sides rusty because I love the way it looks.
Step 3: What's Your Handle?
I was initially going to make a handle from an old table leg I had, but after testing it wasn't strong enough. Nowhere near strong enough. It turns out there is a reason they don't make pine hammer handles...
I did want to make the handle but a suitable piece of something suitable (hickory, beech etc) would have cost me WAY more then the £3.80 a hickory sledgehammer handle cost.
I fitted the handle by sanding roughly to the shape of the hammer 'eye'. I then sawed a thin slot at the top that would accept the wedge. I then put the hammer head on the floor and put handle in and whacked away with the big hammer whose fate it is no longer be the big hammer...
Once the handle was flush and firmly fitted I turned it the correct way up and hammered in the steel wedge. Make absolutely certain the hammer is solid.
Saw the handle to a size that suits. Slightly longer than suits, just in case...
I rubbed a bit of linseed oil on the handle.
Step 4: Boom!
Admire your new hammer.
Step 5: Bang!
Hit something with your new hammer.
Step 6: File (no, Hammer...)
Give it pride of place on your wall of hammers. I roughly engraved the weight on the side and then on the side of the other hammers I mainly use so that I can see at a glance what to expect. But I expect I am the only one dumb enough to want this.
I've used it a few times now, and I can honestly say it is the best hammer I have used. It's not for every job, but it has plenty of whack when you need whack.
Be the First to Share
    • For the Home Contest
    • Big and Small Contest
    • Game Design: Student Design Challenge
    9 Comments
    John Harwood
    John Harwood
    4 years ago
    Why didn't you use the other part of the sledgehammer handle, the one with the bulbous end? The part you fitted tapers towards the end, which can't be good for holding onto when swinging with force. Apart from that, I have to say how I admire your steel-sculpting ability. I need to get a flap-wheel for my cheap-though-strangely-long-lived 115mm grinder, which I bought from Netto just before they went bust.
    LaurenceB23
    LaurenceB23
    Reply 4 years ago
    Ah, I probably wasn't paying too much attention... Actually, I intend to make 2 of these sledgehammer hammers and will be using that end next time. Also, where I intended to the base of the handle to be is fairly thick. I left a few extra inches on as a bit of a test run to see how it worked. Definitely get a flap wheel, they are fantastic!
    turtleman1
    turtleman1
    Question 4 years ago on Step 6
    What is the final weight of the hammer head?
    LaurenceB23
    LaurenceB23
    Answer 4 years ago
    6lb.
    EmmettO
    EmmettO
    4 years ago
    I don't need a really big hammer but I do need a good straight peen hammer. Maybe I'll make one this way.
    PeterC151
    PeterC151
    4 years ago on Introduction
    Good Stuff, recycling an old sledge hammer head, great w/shop too. Question would you have any sketches drawings of your gas furnace I would like to build one, yours glowing away in the picture is magic and I bet it doubles as heater in Winter.
    LaurenceB23
    LaurenceB23
    Reply 4 years ago
    Sorry, I just bought the propane forge from eBay...
    Alex in NZ
    Alex in NZ
    4 years ago
    Really neat, and I love your "wall of hammers." As someone who lives in an earthquake zone, I do rather flinch at putting them so high, but that's not a problem for you.
    joen
    joen
    4 years ago
    Nice! After seeing your hammer wall of honor, I can see why you needed the one that you made. By the way I don't see an issue with labeling your hammers. I have labeled some of my stuff like that as well. So either you aren't "dumb enough" or we both are. Take care.
