Introduction: Adaptive Game Controller for Cerebral Palsy
controller #1 (quadriplegia)
this controller requires the use of one foot.
to operate, users place one part of their foot in the center "ground" circle and tap on the outer circle controls, completing the circuit. For the upper controls, users tap "up" "down" or "space" with their toe while keeping their heel in the center circle. For the lower controls, users tap "left" "right" or "click" with their heel while keeping their toe in the center circle.
controller #2 (diplegia)
this controller requires the use of one arm.
to operate, users place the length of their arm vertically on the board with their fist closed. they can then switch between controls by sliding back and forth across the board, connecting the circuit between the lower "ground" strip and the individual controls.
I created both controllers with accessibility and simplicity in mind. I wanted them to be really easy to make and natural to use, for all physical abilities. I didn't want my controller to pose a disadvantage to gamers (especially since video games are often competitive) and tried to make the reaction time as fast as a generic game controller or computer keyboard.
- thick foam board
- xacto knife (and extra blades)
- tinfoil
- copper/conductive tape
- hot glue
- tacky glue
- paint (optional)
- masking tape (optional)
- pen (optional)
- foam board
- tinfoil
- pen (optional)
makey case
clip cover
Step 1: Gather Supplies
(listed above)
Step 2: Cut
- cut a rectangle out of thick foam board
- cut a slot from the center circle to the edge of the board
- cut indented circles into the board (7 total)
- cut 7 ovals out of tinfoil (folded over to be multiple layers)
- cut 7 small squares out of tinfoil
- cut a long rectangle out of foam board
- cut a long strip of tinfoil (folded over to be multiple layers)
- cut shapes out of tinfoil for controls: up/down/left/right arrow, square (space), and circle (click)
Step 3: Attach
- glue tinfoil ovals into indented surfaces
- use copper/conductive tape to secure tinfoil to board
Step 4: Wiring
- attach a strip of copper/conductive tape leading from each control to the edge of the board
- use hot glue to secure tinfoil squares to the copper tape
Step 5: Connect
- use alligator clips to connect the makey makey to each tinfoil square
- use alligator clips to connect the makey makey to each strip of copper tape
Step 6: Label
- label each control and corresponding wire using masking tape (up, down, left, right, space, click)
Step 7: Decorate (optional)
- paint the outline of each circle with a different color
Step 8: Test
- connect makey makey to computer
- go to scratch.com and test your controller!
https://scratch.mit.edu/projects/735139462/
