Introduction: Adaptive Lego Lideo Game Controller
Hello everybody, this is the instructable for my Lego technic adaptive controller that I have made. It is super simple to make and when finished has up to four completely customizable buttons, I tried to design a controller that could be used with minimal movement and still have good outputs. The first video is an explanation of how the controller works, and the second video is a demo of the controller.
1. Makey Makey STEM Kit
https://www.amazon.com/JoyLabz-MMCE-Makey-Invention-Everyone/dp/B008SFLEPE?th=1
2. Electrical Wire
https://www.amazon.com/THUN-CT-Electrical-65-62ft-Tinned-Stranded/dp/B09WQQC8ZC/ref=sr_1_2_sspa?keywords=thin%2Bcoated%2Bwire&qid=1700114879&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
3. Lego Technic Parts
https://www.amazon.com/Technical-Parts-Beams-Connectors-Bricks/dp/B0B4NDJRKZ/ref=sr_1_6?crid=3CZLAWPDUOSWF&keywords=lego%2Btechnic%2Bparts&qid=1700115020&sprefix=lego%2Bte%2Caps%2C159&sr=8-6&th=1
4. Copper Foil Tape
https://www.amazon.com/Conductive-Shielding-Deterrent-Soldering-Grounding/dp/B09C5ZDBVL/ref=sr_1_2_sspa?crid=250NU66FUTE3I&keywords=copper%2Btape&qid=1700115166&sprefix=coper%2Btape%2Caps%2C147&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
5. Thin Plywood Sheets
https://www.amazon.com/Pack-Basswood-Plywood-Sheets-Crafts/dp/B0B5MQTHXD/ref=sr_1_7?crid=3A07E8O41R2G0&keywords=thin%2Bplywood%2Bsheets%2Bfor%2Bcrafts&qid=1700115236&sprefix=thin%2Bplywod%2Caps%2C148&sr=8-7&th=1
6. Duct Tape
https://www.amazon.com/GRAY-RHINO-Waterproof-Tearable-Packaging/dp/B0C2H9176R/ref=sr_1_4?crid=1KAWCP0SRWS48&keywords=duct%2Btape&qid=1700115310&sprefix=du%2Caps%2C169&sr=8-4&th=1
If you want to test your makey makey controller try this fun piano game.
https://apps.makeymakey.com/piano/
If you want to 3D print a box to hide your wires use this!
https://a360.co/40mz4yg
Here are some instructions on how to remap your Makey Makey
https://makeymakey.com/pages/remap
Step 1: The Legos
Above is a video showing how to assemble the Lego pieces. The gold wrap that is around some of the pieces is the copper tape used to make it conductive.
Step 2: The Wires
These videos are going to show you how to wire up your controller and make sure that the conductive parts are working properly.
Make sure not to use too much copper tape because it has messed up the conductive pieces in the past.
Step 3: The Board
This video is going to show you how to make the board that you were going to be mounting the entire controller on to. I used hot glue to make the feet on the bottom but you can use any rubber or plastic you like.
Step 4: Put It All Together
Once you have both the controller, and the board made, put them both together, and you have a working controller!!!
