Adaptive Toy - Dancing Robot
Intro: Adaptive Toy - Dancing Robot
This toy can be switched on and off with a small switch on the back of the robot which will be challenging for a person dealing with a motor delay or disability. To make it accessible, a large brightly colored external button will be added that will activate the toy.
I used the Intructable "Switch Adapted Giggle Pig" by daveat to get me started on how to adapt this toy. https://www.instructables.com/How-to-switch-Adapt-...
STEP 1: Expose Switch
Remove all six screws from the body using a Phillips head screwdriver. Since the body will not completely separate due to a retaining clip in the front, gentlly separate the back of the robot and remove the switch to expose the wires.
STEP 2: Add Female Mono Jack
Solder a wire to each of the leads on the back of the switch. Then solder the other end of those wires to a 1/8” female mono jack.
STEP 3: Install the Audio Jack
Choose where you want to feed the audio jack though the outer shell and drill a hole in this location. Feed the jack out and tighten the nut fixing it in place.
STEP 4: Testing
Now that all of the wires are connected, test to see if the modifications you've made still allow the toy to function properly. Doing this before reassembling the toy will make it easier to identify and fix any problems you may find.
STEP 5: Reassemble
Reposition all of the plastic pieces and align the two halves of the toy. Then reinsert all the screws and reinstall the batteries.
