Introduction: Add Aux to Sonos Using Raspberry Pi
I have always been fascinated by the Raspberry Pi but never had a real need for one until now. We have three Sonos components in our house: A Play 5 in the living room, a Play 3 in the bedroom and a Sonos CONNECT:AMP powering outdoor speakers on our patio. With them we can listen to practically anything except our local radio station which doesn't stream over the Internet. I have a tabletop radio upstairs in my office that has a line-out and wanted to be able to listen to it throughout the house mainly for live sports broadcasts. I could have accomplished this by buying another Play 5 or CONNECT and using its line-in but I didn't have enough room in my little office nor did I want to invest that much more money just to have that capability. I decided to learn how to program a Raspberry Pi to add a remote line-in for our Sonos speakers. I wrote this Instructable for the complete Raspberry Pi NOOB, which I was until just a few days ago, with what I feel is the most concise, least amount of steps necessary to have a Raspberry Pi automatically start serving a live 320 kbps stereo mp3 stream to Sonos within seconds of booting up. This is also the perfect way to listen to your turntable throughout the house on Sonos.
Step 1:
What you will need:
Raspberry PI 3 Model B 1.2GHz 64-bit quad-core ARMv8 CPU, 1GB RAM
A desktop or laptop computer with a microSD card reader
Monitor or TV with HDMI input (for initial setup only)
USB or bluetooth keyboard and mouse (for initial setup only)
BEHRINGER U-CONTROL UCA202 External USB Soundcard (has stereo RCA inputs)
or
Cheap $10 USB stereo capture card
UPDATE: If you own a turntable with USB out you may be able to just plug that into the Pi and use that as the "soundcard" and forego buying the Behringer altogether.
EDIT: I wasn't aware that Behringer has another model for the same price called the BEHRINGER U-PHONO UFO202 that has a built-in Phono preamp for turntables.
The Raspberry Pi's on-board sound card does not have audio inputs and there are very few external USB sound cards that have stereo inputs. My second choice was a stereo sound card "hat" that plugs into the Raspberry's GPIO pins but I couldn't find a case for it and I really liked the look and functionality of the Flirc Raspberry Pi case.
Flirc Raspberry Pi Case Gen2 (New Model) (aluminum case acts as a heat sink)
Mediabridge 3.5mm Male to 2-Male RCA Adapter (6 Feet) (if your analog audio source has RCA outputs then you don't need this)
Step 2:
Navigate to https://www.raspberrypi.org/downloads/noobs on your regular computer and download NOOBS_v2_4_4.zip. It is a rather large file (~1.4 GB). Extract the contents of the zip file to your microSD card. I found it was faster writing to my SD card by first extracting the files to a temporary folder and then copying them to the card rather than extracting directly to the card.
Step 3:
Insert the microSD card with the extracted files into the SD card slot on the underside of the Raspberry Pi. Connect an HDMI cable from the Raspberry Pi to your monitor or TV. Connect the USB keyboard, mouse, ethernet cable (or you can configure Wi-Fi later), USB soundcard (the Behringer card doesn't require any additional software or drivers) and finally the Micro USB power cable.
Step 4:
The Pi will boot up to the operating system installation screen. Select only Raspbian and click Install. It will take a while to install. During my installation a little lightning bolt icon would appear intermittently at the top right of the screen. Online research revealed that if the Pi is accessing the microSD card a lot or otherwise working hard (and powering an external USB sound card in our case) and you are powering it using a USB cable plugged into a computer (not a dedicated USB power supply) you may see that icon which indicates a little undervoltage. It's perfectly normal and shouldn't affect anything. After the OS finishes installing you will get a confirmation dialog box. Click OK and the Pi will reboot.
Step 5:
After it reboots the Raspbian desktop will appear. The first thing we need to do is set a root password. Click the terminal icon on the upper left of the screen and type in "sudo passwd root" (without the quotes) and hit enter. Type in "raspberry" (without the quotes) as the password, hit enter and then type it in again and hit enter to confirm. BTW, the command "sudo" stands for "super user do" and allows you to execute commands as a super user aka root user.
sudo passwd root
Step 6:
Next we're going to enable the built-in VNC server. This makes things so much easier as you can simply copy and paste commands via VNC rather than typing them. Select GUI Menu (the little raspberry on the taskbar) > Preferences > Raspberry Pi Configuration > Interfaces. Click Enabled next to VNC and then OK. After a few seconds a VNC icon will appear on the taskbar. Click it and then the menu icon at the top right (box with 3 horizontal lines) and then Options. In the Security options set Encryption to "Prefer off" and Authentication as "VNC password". A password box will pop up. Enter "raspberry" (without the quotes) for the password into each box and click OK. You will get a second warning box that you have to click OK to confirm. We're setting up an audio streamer, not storing nuclear codes :)
Step 7:
Before we go any further we need to assign a static IP address. If your Pi's IP address is randomly assigned by your router's DHCP server, then the IP address could change later and you wouldn't be able to connect via VNC (or Sonos for that matter). RIGHT-click the network connections icon on the taskbar (the little up and down arrow icon) and select "Wireless and Wired Network Settings". LEFT-click the upper right box and select "eth0" to configure the ethernet connection or "wlan0" for wireless. I would advise assigning a static IP to only one or the other. I had a problem when I first set up my Pi where I assigned the same static IP address to both connections and my Pi's wireless locked up and I couldn't get it back working correctly so I had to start all over installing the OS. Anyway, enter the IP address you want in the IP address field and enter your router's IP address in both the Router and DNS Servers field. Click Apply and Close.
NOTE: It may be easier to assign a static IP address using your router's DHCP IP reservation feature if it has one. You may need the MAC address of the Pi or it may just show up in a list of connected devices on your router's admin page. If you need the MAC address then type in the command "ifconfig eth0" in the terminal window for ethernet or "ifconfig wlan0" for WiFi. Interestingly enough the WiFi's MAC address will show up on the line that begins with "ether"
Step 8:
Next we need to set the default screen resolution. This may seem silly seeing as how we're already connected to a monitor but later when you connect via VNC without a monitor attached (headless, as they say) it will revert back to the Pi's default 640x480 resolution which is a very tiny screen to work with! Select GUI Menu > Preferences > Raspberry Pi Configuration > Set Resolution. Set it to 1280x720 or higher and click OK and Yes to reboot.
Step 9:
At this point you may want to start using VNC to control the Pi. Open up the VNC control panel on the Raspbian desktop again and look for the IP address under "Connectivity". Install and run a VNC viewer on your regular computer and use that IP address to connect and enter "raspberry" (without the quotes) as the password. I used TightVNC for Windows. After you've connected you can save the Pi's VNC connection as a shortcut on your desktop to quickly connect in the future bypassing the logon screen. You will get a warning about saving the password within the shortcut. Again, the codes. To copy and paste into the Pi's terminal window, select or highlight the text or commands on your regular computer, hit Ctrl-C (literally hit the Ctrl and C key on your keyboard at the same time) or right-click and select "Copy", then activate the Pi's VNC viewer window and RIGHT-click inside the terminal window right on the cursor and select Paste.
Step 10:
Next we are going to test the sound card to make sure it is working properly. Plug a live audio source into the USB sound card's RCA line inputs. Open the terminal window and type in "arecord -l" (that's a lowercase "L") and hit enter. That will list your attached sound card devices. The number after the word "card" is your device number. Substitute that number in the next command after the word "plughw:" In my case my card number was "1" so I typed in (actually copied and pasted using VNC) "arecord -D plughw:1,0 -f cd temp.wav". That will start recording a CD-quality .wav file from the sound card's inputs. After a few seconds hit Ctrl-C (literally hit the Ctrl and C key on your keyboard at the same time) to stop the recording. To play it back you will need to plug headphones into the headphone jack located on the Raspberry Pi card itself or the headphone jack of the external USB sound card. RIGHT-click the speaker icon on the taskbar and select the corresponding device you just plugged your headphones into and turn up the volume (Analog = Raspberry Pi headphone jack; USB AUDIO CODEC = External USB sound card headphone jack). Type in "aplay temp.wav" and hit enter and you should hear what you just recorded. The sound card on the Pi is not very good so if you are listening via its built-in headphone jack, don't be alarmed if it doesn't sound all that great. Our audio stream will be all digital and will sound great on Sonos.
arecord -l
aplay temp.wav
Step 11:
Next we are going to install two programs, Darkice and Icecast2. Darkice is what will be encoding our live audio source into an mp3 stream and Icecast2 is what will be serving it to Sonos as a Shoutcast stream. Type in each of these lines in the terminal window one at a time followed by the enter key each time:
wget https://github.com/x20mar/darkice-with-mp3-for-raspberry-pi/blob/master/darkice_1.0.1-999~mp3+1_armhf.deb?raw=true
mv darkice_1.0.1-999~mp3+1_armhf.deb?raw=true darkice_1.0.1-999~mp3+1_armhf.deb
sudo apt-get install libmp3lame0 libtwolame0
sudo dpkg -i darkice_1.0.1-999~mp3+1_armhf.deb
Step 12:
Now to install Icecast2. Type in "sudo apt-get install icecast2" followed by enter. After it installs a window will pop up asking if you want to configure Icecast2. Hit the left arrow key and enter to select Yes. On the second screen hit the down arrow key and enter to select OK to use the default hostname "localhost". On the next three screens hit the down arrow and enter key to agree to use "hackme" as the default source, relay and administration password. Even though we are agreeing to all of the default settings, these steps must be completed to activate the Icecast2 server.
Step 13:
Next we need to run the GUI file manager as root user. To do this, select GUI Menu > Run. Type in "sudo pcmanfm" and hit enter. That will open up the file manager (the equivalent of file explorer for us Windows users) to the home directory (/home/pi) and you will see the leftover darkice installation file we previously downloaded along with the temp.wav file we created to test the sound card. RIGHT-click on an empty space in the explorer window and select Create New and then Empty File. Name it "darkice.cfg" and click OK. Then RIGHT-click that newly created file and choose to open it with Leafpad (the equivalent of Windows notepad). Copy the lines below and paste them into Leafpad then click File and Save. The settings I have selected are for the best quality mp3 stream but you may want to tweak them to lower quality settings if you are going to be streaming outside your network e.g. the Internet. Make sure your sound card number is correct in the line "device = plughw:1,0" You'll notice the "quality" line is commented out with a # in front of it. It is used only if you set "bitrateMode = vbr" (variable bitrate). You can't have a quality value set when using cbr (constant bitrate) or the stream will stutter and skip. I only discovered this little gem after many hours of frustration. I assumed the quality value would be ignored if you were using cbr but it turns out that is not the case and really throws a monkey wrench into the works. Conversely, if you decide to use vbr then you need to comment out the "bitrate = 320" line and uncomment the "quality" line.
[general] duration = 0 # duration in s, 0 forever bufferSecs = 1 # buffer, in seconds reconnect = yes # reconnect if disconnected [input] device = plughw:1,0 # Soundcard device for the audio input sampleRate = 44100 # sample rate 11025, 22050 or 44100 bitsPerSample = 16 # bits channel = 2 # 2 = stereo [icecast2-0] bitrateMode = cbr # constant bit rate ('cbr' constant, 'abr' average) #quality = 1.0 # 1.0 is best quality (use only with vbr) format = mp3 # format. Choose 'vorbis' for OGG Vorbis bitrate = 320 # bitrate server = localhost # or IP port = 8000 # port for IceCast2 access password = hackme # source password for the IceCast2 server mountPoint = rapi.mp3 # mount point on the IceCast2 server .mp3 or .ogg name = Raspberry Pi
Step 14:
Next we need follow the same steps as before to create an empty file called "darkice.sh". An .sh file is the equivalent of a .bat or batch file for DOS or Windows. Open using Leafpad, copy and paste the lines below and save.
#!/bin/bash sudo /usr/bin/darkice -c /home/pi/darkice.cfg
Step 15:
Next we need to run a command to make the darkice.sh file executable. Open the terminal window and type in "sudo chmod 777 /home/pi/darkice.sh" and hit enter. Now it's time to start the Icecast2 server service. Type in "sudo service icecast2 start" and hit enter.
Step 16:
Next we need to tell Darkice to start automatically whenever the Pi is booted (the Icecast2 server runs as a service and already starts automatically after booting). First we need to select which text editor to use. In the terminal window type "select-editor" and hit enter. Type "2" to select nano editor and hit enter. Then type "crontab -e" and enter. Next hold the down arrow key down to scroll all the way to the bottom of the text file that appears and add this line "@reboot sleep 10 && sudo /home/pi/darkice.sh". Then hit Ctrl-X to exit and it will prompt "Save modified buffer?". Hit the Y key for Yes then enter to confirm whatever filename is automatically generated. The sleep 10 switch tells the Pi to wait 10 seconds after booting before starting the audio stream. This gives the OS time to initialize the USB sound card. If you start the stream before the USB sound card is active, the stream will never start.
select-editor
crontab -e
Step 17:
Click the GUI menu icon and select reboot. If you followed all these steps precisely then the stream will start automatically anywhere from 30 seconds to a minute after clicking reboot.
Step 18:
UPDATE: I cannot get my stream to play directly in Google Chrome anymore. I think it got broken with a Chrome update. It still works fine on Sonos and my other streaming apps.
To test that the stream is working correctly, open the web browser on your regular computer and navigate to "http://192.168.1.146:8000" (with your Pi's correct IP address substituted for mine of course) to view the status of your Pi's Icecast2 server. To listen, click on the M3U icon in the upper right or you can manually enter "http://192.168.1.146:8000/rapi.mp3" to open the stream directly and skip downloading the .m3u playlist file altogether. If you hear your live source then the Pi is working correctly and it's time to add it to Sonos.
Step 19:
You must use the Sonos desktop controller app to add a custom stream to Sonos. Click on Manage > Add Radio Station and enter the url for the stream which in my case was "http://192.168.1.146:8000/rapi.mp3". Also enter a Station Name and click OK.
Step 20:
To play the custom radio station we just added, select "Radio by Tunein" and then "My Radio Stations" and then you will see your Raspberry Pi listed. LEFT DOUBLE-click to play or RIGHT-click to edit or add the station to your Sonos favorites.
Step 21:
After adding the custom radio station it will immediately be available on your Sonos mobile app. Sonos recently updated their app to a ghastly white motif as well as renaming "Sonos Favorites" to "My Sonos" and using overly large thumbnails for everything. There has been a lot of backlash on the Sonos forums as the old format looked and worked so well with everything easily accessible without blinding you in a dark room. Hopefully they will revert back to the old style soon. Anyway, on the new app, tap "My Sonos" at the bottom, scroll down to "Stations" and tap "See All". On the next screen scroll down until you see "Raspberry Pi". Tap on it and it will start playing in your selected room(s).
Step 22:
The last thing to do is to install the Pi in a case. I chose the Flirc Raspberry Pi Case because it both looks good and is functional. The entire aluminum case acts as a heat sink for the Pi's processor. If you get this case, peel off the sticky side of the spongy thermal pad that is included and stick it on the part of the case that reaches down to touch the processor and then peel off the thin plastic film on the other, non-sticky side (the side that touches the processor) before closing up the case.
Step 23:
Just a bit of house cleaning: If you plan to leave your Pi connected via ethernet then you may want to turn off its Wi-Fi radio to conserve a little juice. To do this LEFT-click the network connections icon (the little up and down arrow icon) and select "Turn Off Wi-Fi". You can also turn off the bluetooth radio by LEFT-clicking the bluetooth icon. Also, the Darkice program runs hidden in the background so if you ever need to stop it then open a terminal window, type in "ps aux | grep darkice.cfg" and hit enter and then "sudo kill 976" (or whatever the first process ID is) and hit enter. To restart the stream type in "sudo darkice -c ~/darkice.cfg" and hit enter or just simply reboot. I was curious how much bandwidth the Pi used when there were no clients attached to the Icecast server so I installed a bandwidth monitoring tool called vnstat and the answer is 0 kbps. If there are no clients connected then there is absolutely no bandwidth used whatsoever. Good luck and thanks for looking!
sudo kill 976
Step 24:
UPDATE November 2018: I moved out of state recently and wanted to to continue to listen to my sports team's game broadcasts on my Sonos speakers. I wrote a script 17 years ago that reads all my team's sports schedules every morning to see if there's a game being played that day. If there is it sends me an email, sets my computers Hauppauge Colossus HDMI capture card to record the game from the cable box and Total Recorder records the radio broadcast from a radio connected to my computer's line-in. Since I am going to be out of state the radio does me no good now so I set up a Raspberry Pi to automatically launch the game broadcast stream in a web browser when it is booted. So what happens now is when the pregame starts my computer automatically turns on a Wemo switch connected to the Pi and it boots and starts playing the radio broadcast and I record from the Pi's headphone out using my computer's line-in. I was having my main computer launch the webpage and recording it internally but I didn't like having my computer tied up the whole game. I also wanted to stream the audio to my Sonos speakers and thought it would be simple to do using only software but it turns out that is not the case since Darkice is looking for an audio input signal, not an output. The easiest and most reliable way is to simply plug one end of a 3.5mm to 2x RCA adapter into the Raspberry Pi's headphone out and the other end into the Behringer's RCA inputs and perform the steps in this instructable to stream the AUX input from the Behringer. FYI, to automatically launch a webpage at boot you need to edit the autostart file in /etc/xdg/lxsession/LXDE-pi/autostart and add this line at the end:
@chromium-browser https://tunein.com/radio/Ole-Miss-IMG-Sports-Netw...
It works great!
Step 25:
UPDATE June 4, 2019: Streaming the live audio from my sports team's TuneIn webpage to Sonos has been working great except the last few broadcasts the volume has been very low. I loaded some YouTube videos and they were loud and clear so a volume setting somewhere between the stadium and TuneIn's servers must have gotten lowered. Not a big deal as I'm sure it get rectified but it got me to thinking of a way to boost the volume of the Raspberry Pi's sound output to the Behringer external sound card without using a separate headphone amp. I ordered a cheap $10 USB sound card with a stronger output and physical volume control but had to make a few changes to get the Raspberry Pi to recognize it as the default sound card.
To disable the Pi's onboard sound card you have to click the GUI Menu icon on the desktop (Raspberry logo), then click Run and enter "sudo pcmanfm" to open the File Manager as root user. Then navigate to /etc/modprobe.d/ and open the "raspi-blacklist.conf" file using leafpad and add the line "blacklist snd_bcm2835" (without the quotes) and save. Then navigate to /lib/modprobe.d/ and open the "aliases.conf" file and comment out the line "options snd-usb-audio index=-2" by inserting a hashtag in front of it so it reads like so: "#options snd-usb-audio index=-2" then save. Reboot then open the terminal window and type in "arecord -l" to list the capture devices to make sure the Behringer sound card is still the same device number (the number after the word "card") that's listed in your darkice.cfg file on the line:
That's it. These changes will allow a USB sound card to be the default sound for everything on the Raspberry Pi. You can right-click on the speaker icon on the desktop and select which USB sound card is the default one.
Step 26:
UPDATE June 5, 2019: When I ordered the USB sound card referenced above I also ordered a cheap $15 USB capture card that has stereo inputs to see if it could both be used with the Raspberry Pi as a cheaper alternative to the Behringer card and if it had software capture controls and the answer to both is yes! To activate the capture controls right-click on the speaker icon and click "USB Device Settings..." then click "Select Controls..." then check the microphone box and click "Close". Even though it only has "Microphone" as an option I can confirm that it is indeed a stereo input using either the 3.5 mm or the RCA inputs.
Runner Up in the
Raspberry Pi Contest 2017
34 People Made This Project!
- PowerChap made it!
- guuuuuuul made it!
- pauwels_vanhastel made it!
- rhyantbrown made it!
- loubardnux made it!
- zackcr made it!
- Frogro made it!
- paul.w.blyth made it!
- Drstrangedds made it!
See 25 More
196 Discussions
Tip 2 months ago
Looks like a lot of people are running into the same issues I did when setting this up. I followed all the instructions correctly, but all I was getting when I typed in my IP was an empty icecast2 status page... I searched everywhere for an answer but couldn't find a solution that worked.
I was about to remove the darkice and icecast2 software on my pi to try reinstalling for the third time when I stumbled upon an application called Darksnow. I did a
sudo apt-get install darksnow
and once it installed, I opened the application located in the "other" section of the GUI menu. The app is fairly simple, it basically just builds your config file for you. I'm still a noob at this sort of thing so it took me a few tries to get the settings right for it to work, but eventually it stopped giving me errors and the stream started!
I've posted screenshots of the settings I'm using. Not sure if they're the most ideal values, but I was just happy to get it working!!
Here are a few things to note that I learned in the trial and error:
- I tried using my IP address under the "server" setting but it didn't work until I changed to localhost.
- As far as I can tell you can set the mountpoint to whatever you want. I set mine to turntable.mp3. (This is what you add after the ip:8000 to get your stream address ex: 10.0.2.195:8000/turntable.mp3)
- The password is hackme provided you didn't change it.
- Verbosity level is something I wasn't quite sure about. The stream wouldn't start unless I entered a value so I just set it to 0 and haven't noticed any issues...
- I encountered some skipping issues when the bitrate was set to constant so I tried variable and it's worked much better.
- My device input wasn't listed under the dropdown options so I had to type it in manually. (In my case the device was registered under card 2)
- Apparently the streaming description isn't necessary, but I titled mine Turntable to identify it in case I ever decided to add any other icecast streams.
- If you click the start streaming button and nothing is happening, you're probably missing a required value. I didn't figure this out until I clicked the "show details" button at the bottom of the window. This is where you can see any error messages that return.
Once you have a configuration that works, do a file>save and put the config in a place where you can find it again (I put mine on my desktop). That way if you have to open up DarkSnow again to start the stream you can easily open the configuration from that file.
I'm not sure if this will all just work when I reboot the computer or if I'll have to go into DarkSnow and click the start stream button every time, but this was the simplest solution I found.
Hope this helps!
Also thanks to replayreb for the tutorial, it got me most of the way there ;)
Reply 9 days ago
Hi, thank you so much for this addition. I tried to copy the exact settings you used above, but only when I changed the bitrate to CBR and 256 (for a MP3) it worked. All of a sudden I did see that the Icecast server actually did something! Very happy!!
Reply 12 days ago
Wow -- was totally stuck before I saw your comment. Thank you thank you thank you! Have you found any solution so you don't have to reopen each time?
Reply 14 days ago
Thanks for the tip- works well. But I have to manually start Darksnow every time (and pull the correct saved data) and start streaming. Tips on how to get Darksnow to save my inputs and start on reboot every time?
Reply 5 weeks ago
I finally managed to get it to work.
Thanks to Ryantbrown. Darksnow software seems to be working.
I still have to turn the volume up too low, the problem is that I have to restart Darksnow stream manually every time.
Ryantbrown found the solution, can you share ?.
Thank you
Question 14 days ago on Step 17
Stuck at Step 17. Not able to get Darkice to start streaming upon reboot. Icecast shows nothing streaming. I have to manually start Darksnow streaming in order to make things work. Once I start Darksnow, I see streaming in Icecast and am able to stream through Sonos. I have tried redoing all the steps outlined in the original instructable, and have also tried some of the improvements in the comments. Any ideas how to get things streaming upon reboot, so I don't have to do more than startup in order to stream my turntable to Sonos?
Answer 12 days ago
I changed step 17 to sleep 20 and it seems to reliably start up darkice now. 10 must not have been long enough for mine too boot.
Reply 12 days ago
I tried that too, but it didn't fix the problem. Do you make sure your turntable is running before you boot the Pi? Could that be connected? In the meantime, I'll try again with ta longer sleep command.
Reply 12 days ago
What happens when you run `sudo /home/pi/darkice.sh`?
Does it start manually? It won't auto start if that command also fails.
My turntable doesn't have to be running, but it is connected. It might be outputting a signal even though it's powered down.
I've gone through a bunch of trouble shooting related to outputs changing in the config and static ip addresses changing so might be able to help further if that the darkice.sh doesn't work
Answer 12 days ago
Only after starting it manually
Question 4 weeks ago
Hi All, I am going to give this a shot - Turntable => Sonos is perfect for me.
One question though, with this set-up how do you power-down the Pi?
Just switch off power and hope for the best??
Answer 12 days ago
Make sure no green lights are flashing (reading/writing sd card) and turn off the power
The safest option is the sudo shutdown when ssh'd in. Or use VNC to manually shutdown via the UI
14 days ago
This worked great for me, so thanks! My only problem was darkice would NOT start using the crontab -e entry. I tried a bunch of things, but eventually rather than pulling darkice via the GitHub link, I ran sudo apt-get install darkice which setup it up as a running service.
I then followed this link: https://wiki.radioreference.com/index.php/Live_Aud...
to replace the /etc/init.d/darkice service file and now it runs properly after a reboot and the record player is working great! Thanks again!
Reply 12 days ago
Hello
Can you detail your method more precisely
6 weeks ago
While I got this working and I can play whatever the comes in on my custom radio channel. There is a delay introduced so it cannot be used for the audio of Video Sources.... the sound is out of sync. Any idea how to change this? Otherwise a fun and easy project to follow. thanks
Reply 6 weeks ago
As far as I know this can't be avoided. Since it's being streamed through an internet radio station, there's going to be some lag. This solution really only works for audio only streaming where a slight delay in the output doesn't really matter. If you try to stream the station alongside video, the audio is going to be significantly out of sync. Sorry to disappoint :/
Reply 14 days ago
Found this instructable and was very happy because I thought I could use my Sonos Play 3 to stream my PS4's sound. However if you say there are some delays I dont think that this would be a good idea :(
Reply 14 days ago
Yeah unfortunately there's a considerable delay. Sometimes as much as 5-10 seconds. I don't think it's even consistent about the amount of time it takes to get audio from the source to come out of sonos... Might want to look elsewhere for a different solution.
27 days ago
It was working great for a few months, but now it won't play at all. When I press "play" in the sonos app to retrieve the station, nothing happens (the "play" button doesn't turn into a "stop" button so I assume no feed is detected).
6 weeks ago
I got mine working but the audio is distorted to the point you can't understand it. Could my cheap USB capture card be the problem? https://www.amazon.com/gp/product/B07RBCDPSB/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
