Introduction: Add USB Ports to PCI Card!!!
Who couldn't use more USB ports?? Seriously.....
Using a PCI USB card and some Pin Headers, I was able to add TWO more ports to my USB card, giving me a total of SEVEN ports!!
Let the fun begin!!!
Please RATE & COMMENT!!!
Step 1: Parts!!!
1 VIA VT6212L PCI USB card (4 external ports, 1 internal)
You can get one from Amazon for less than $9 (http://www.amazon.com/Media-UH41P-VT6212L-1-Port-Card/dp/B001NG42F4/ref=sr_1_3?ie=UTF8&s=electronics&qid=1229437931&sr=8-3)
And you will need one of these part number 274102 $.25 from Bestlinknetware.com.
Take a close look behind the internal USB port, I wonder what we could do with that.... ;)
Step 2: Trim the Header Pins.
Using a knife, you can just chop off what you need, then pull one of the pins on the corner using a pair of pliers.
Step 3: Solder!
Solder your new pin connector into the holes, and VOILA!!
You will have TWO more ports!
You can also use this on a USB card that only has ONE row of pins, you just will only be able to add ONE Port instead of TWO.
