Introduction: Add Videos to Video Brochures
In this Instructable, I will show you how to add videos to a Video Brochure. It is a fairly easy process
Materials
Video Brochure (I used one by Video Plus Print)
Computer (I used a Chromebook but it works with any computer)
USB to connect Video Brochure to Computer (This usually comes with the Video Brochure)
Step 1: Attach to Computer
Plug the Video Brochure into the Computer with the USB
The screen of the Video Brochure should say that it is charging once plugged in
On your computer, it should show the files from the Video Brochure as a removable device
You should see the four .avi files in the file VPPGLOBAL
If you are using different Video Brochures, the files may not be .avi, but the process is the same
Step 2: Convert Video
To add a video to your video brochure, you have to convert it to the correct layout
If your video is a .mp4, you have to convert it to a .avi
If your video brochure has a different format, you have to convert it to the format of the videos on the video brochure
You also have to make sure that the video has the same size format (there are many websites online that can do this for you)
The format for the video I had is shown in the picture above, but it may be different for yours
Step 3: Add Video to Brochure
You have to name your video 5.avi before you add it to the video brochure file (or .mp4 if your video has that format)
Then put the video into the VPPGLOBAL file
Once that is done, eject the brochure and unplug it from your computer
You now have another video on your video brochure!
