Add Sound Reactive LED's for Any Speakers!
Intro: Add Sound Reactive LED's for Any Speakers!
So, there's what you need :)
1-10 LED's, Any color, any size (I used 2x 5mm red LED's)
Drill & LED-sized (5mm usually) drill bit
Little rasp to file LED's holes to fit with your LED's
Speakers , I used Creative TravelSound -speakers
Screw driver (if required for removing the speaker boxs cover)
4 Wires (1-30cm, that's about your speaker's size and where do you want to place the led's)
So, let's get started! :)
Video about all this :
STEP 1: Select the Place for LED's
You need to select the place for LED's, and mark it with a pencil. Check that you have space inside the speaker box for leds!
STEP 2: Drill Holes to the Marked Places
Drill holes to the marked places where the LED's comes. Use rasp to make hole to fit with the LED.
STEP 3: Solder
You need to solder your wires to the speakers + and - sides, the sides with the LED's does not matter.
Then solder your LED's + or - side to the wire, and solder the other wire to the other LED side too. Do this step again with the another speaker.
STEP 4: Place the LED's
Put your LED's to the holes you drill'd. Check that your wires does not touch each other, or your speakers does not work!
STEP 5: Finishing
Put case back together, and enjoy!
39 Comments
hemmikarl 14 years ago
marselsipod 14 years ago
hoihoi151 14 years ago
sammons 14 years ago
Phil
synthdust 11 years ago
FrostEnergy 14 years ago
aduy 12 years ago
kool1zero 12 years ago
alienhoodlumz 14 years ago
hunterbait93 14 years ago
samanen 14 years ago
Nija 13 years ago
ivanjacob 12 years ago
curious youth 11 years ago
0xCyrusx0 13 years ago
biggunner 13 years ago
Frag 13 years ago
