Adding a Current Limit Feature to a Buck/Boost Converter
Intro: Adding a Current Limit Feature to a Buck/Boost Converter
In this project we will have a closer look at a common buck/boost converter and create a small, additional circuit that adds a current limit feature to it. With it, the buck/boost converter can be used just like a variable lab bench power supply. Let's get started!
STEP 1: Watch the Video!
The video gives you all information you need to recreate the circuit. In the next steps though, I will present you some additional information.
STEP 2: Order Your Components!
Here you can find a parts list with example seller (affiliate links):
Aliexpress:
1x Buck/Boost Converter: https://s.click.aliexpress.com/e/_dTevK0K
1x LF33 Voltage Regulator: https://s.click.aliexpress.com/e/_dT0fKCw
1x 10nF Capacitor: https://s.click.aliexpress.com/e/_dU4FEsB
1x 10µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
1x 0.1Ω Current shunt: https://s.click.aliexpress.com/e/_dSyQdMA
2x 3.3kΩ, 2x 100kΩ Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
1x MCP602 OpAmp: https://s.click.aliexpress.com/e/_dTvJRGw
1x 10kΩ Trimmer: https://s.click.aliexpress.com/e/_dTFyPv5
1x UF4007 Diode: https://s.click.aliexpress.com/e/_dYR45Bh
1x Voltage/Current Meter: https://s.click.aliexpress.com/e/_d8lymHM
Ebay:
1x Buck/Boost Converter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LF33 Voltage Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 0.1Ω Current shunt: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 3.3kΩ, 2x 100kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MCP602 OpAmp: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Trimmer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x UF4007 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Voltage/Current Meter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Buck/Boost Converter: http://amzn.to/2w1WgTz
1x LF33 Voltage Regulator: http://amzn.to/2w1f2dF
1x 10nF Capacitor: http://amzn.to/2xIowip
1x 10µF Capacitor: http://amzn.to/2habIql
1x 0.1Ω Current shunt: http://amzn.to/2haAOWd
2x 3.3kΩ, 2x 100kΩ Resistor: http://amzn.to/2w2jSaI
1x MCP602 OpAmp: http://amzn.to/2x61uBr
1x 10kΩ Trimmer: http://amzn.to/2x9NmVc
1x UF4007 Diode: http://amzn.to/2w2vzxU
1x Voltage/Current Meter: http://amzn.to/2xJ2YCt
STEP 3: Create the Circuit!
Here you can find the schematic and pictures of my completed circuit. Use it as a reference to create your own.
A rather tricky part is the current path on the output side of the converter. If you want to hook up the current shunt and the V/I meter then your wiring should be like this: Out+ -->Load+ -->Load- --> Red Wire I Meter --> Black Wire I Meter --> Current Shunt 1 --> Current Shunt 2 --> Out-
STEP 4: Success!
You did it! You just added a current limit feature to your Buck/Boost converter!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
28 Comments
Christo_instructables 1 year ago
andratos95 2 years ago
DrEmmanuelGold1 3 years ago
I think the gain is way too big.
adriangalazka15 3 years ago
AllexandruP 6 years ago
duinodude 3 years ago
ОнС 3 years ago
Hi . On MT3608 worked?
aanzur 4 years ago
Is it possible to combine this circuit with your own boost/buck converter ( https://www.instructables.com/id/DIY-BuckBoost-Con... ) ?
Do I just connect the feedback to the gate of the IRLZ44N or is there something else I need to do?
Thank you :)
surac97 5 years ago
DanRiches 4 years ago
I have the exact same module and it works if you connect the 1N4007 diode to pin 5 of the XL6009. You must use a MCP602 though. I tried various TL08x variants and it did nothing but pulse like a stroboscope.
Dan
protoham 4 years ago
vgregorio 6 years ago
Is it possible to replace the MCP602 with an LM358? thank you!
both are op-amp,s so, it-s ok parameters are the same .at me worked
prabhatk13 5 years ago
azad6 5 years ago
Relaf 5 years ago
Whats the maximum current passing through the circuit? How can i make this but in 10 amps version?
aggelos.loykatos 6 years ago
Excellent work! Would it be possible to replace the LM2587 Buck-Boost converter, with one using the XL6009 IC? (of course, using the correct feedback pin). Because the LM2587 ones seem to have gotten either hard to find, or quite pricey. Would any changes be necessary to the current limit circuit?
DIY Circuits 6 years ago
Out of curiosity, is there an LM equivalent of this op amp, and if not a complete equivalent then at least something that would do the job?
PirateKittyK 6 years ago
The ubiquitous LM358 is used in most Chinese modules. Cheap as dirt too.
Polymorph 6 years ago
The ones I have with LM358 current limiting use low side shunt resistance. Which means you absolutely cannot use more than one in a circuit, as you cannot tie the grounds together.
I'm not sure an LM358 will work as intended in this with high side shunt resistance. It is certainly worth a try, but keep in mind that it is a very old op amp. Although it can work in a rather low voltage circuit, the output is limited to 1.5V below V+. So 3.3V is rather low.
