Introduction: Adding a Motor to an Inflatable Boat
This project adds a motor to a small inflatable boat. It re-uses a fan blade from a discarded fan as the propeller. The power is provided by an electric drill.
Fan blade from a discarded electric fan
Threaded rod
4 nuts, same diameter as threaded rod
6-inch length of 1/2 inch tube
Duct tape
Battery powered drill
Small inflatable boat
Step 1: Source a Fan Blade
A fan's blade will be used as the propeller. I was able to source one from an electric fan that had been placed out on the street for waste collection.
Step 2: Shaft
The propeller shaft was a made from a 6mm treaded steel rod. Cut a length of 1/2 inch piece of tube about 6 inches long. This is attached to one of the inflatable boat's oarlocks with duct tape. The shaft goes through the tube and connects to the fan blade.
Step 3: File One End Off the Shaft
On one end of the treaded shaft, file six flat sides. This is so the drill can grip it better without slipping.
Step 4: Fitting the Blade to the Shaft
The fan blade is fitted to the other end of the shaft. The hole in the blade was re-drilled as it wasn't completely round. 2 nuts were placed either side of the blade and locked together to avoid them coming loose and having the fan fall off the shaft while being used.
Step 5: Fitting the Motor to the Boat
Fit the length of 1/2 inch tubing to one of the oarlocks of the inflatable boat using some duct tape. Then slide the propeller shaft through it.
Step 6: Attach the Drill and Go
Attach the battery powered drill to the end of the shaft. I had covered the drill motor in a plastic bag to make it splash resistant.
Using the drill to push the boat along, with a paddle for steering, I went on a 350-meter trip and the motor powered the boat along at about 1 km per hour. It was a bit of fun and surprisingly nothing came a miss (such as the boat getting a puncture, blade falling off Etc.) One drawback of fitting the motor was the noise made by the drill as this takes away the peaceful nature of floating in a boat on a lake.
