Introduction: Adding a Line in to a Boombox With a Tape Player
** As with all the instructables, you take your item / health / whatever into your own hands when attempting ! Be mindful of high voltages on the main power board, the hot soldering iron, etc. Being careful and patient will bring you success. **
This is my first instructable, but I've been doing this sort of thing for a long time !
I know about the cassette adapters, but all the ones that I have tried cause too much background noise.
With this in mind, I decided that I wanted to add a line in to an old boombox that has seen better days, but still sounds good.
I found this baby left for dead on a job site, so I took it and cleaned it up (goof off plastic safe formula), fixed the cd lid, and now I want to add a line in so that I can use it with my mp3 player.
The reason is simple. Now I use an FM transmitter, plugged into a cigarette lighter adapter (which is plugged into the wall), and I hook my mp3 player to the FM transmitter (with an adapter from the 3/32" jack to 1/8") and then tune the radio on the boombox to the transmitter's station.
Besides being bulky, it picks up a lot of static and interference.
The white boombox in the picture was going to get the line in install, but after taking it apart I didn't want to chance breaking it to find the signal from the FM board (or even the CD player).
Step 1: Disassemble
Sony (and many other brands) makes it easy to take their products apart by stamping an arrow by the screws that you need to remove to get the unit apart.
This boombox is model # CFD-S36
I took out all the screws indicated, and that got the front chunk (which holds the speakers) off.
Then I followed the next set of arrows and the unit split into 2 more parts.
Step 2: Locate the Wires From the Tape Head, and See How the Mechanisim Works.
The wires coming from the tape head were easy to spot on this boombox. At first, I thought that since the player had a power button I wouldn't need to press play to get the sound to go through the system, but I found a leaf switch under the board that has to make contact before sound will play through the system.
From there I was thinking about hooking up a toggle switch for the leaf switch, and a toggle switch to cut power to the tape player motor. In many cases the motor causes background noise.
After shopping at Radio Shack for an hour I revised my plan to just a single toggle to cut power to the motor. Pushing play will take care of the leaf switch !
The smallest toggle I could find was a micromini toggle switch, part #275-624 at $2.99
I decided to use a closed circuit 1/8" stereo phone jack, part # 274-246 at $2.99
I'm not sure if feeding a signal back into the tape head will cause any damage, but it may use up some of the signal that I want to be amplified, so the closed circuit switch is the way to go.
The tape head is connected until you plug something into the jack, then the only thing connected is what you are plugging in.
Step 3: Drilling the Holes and Mounting the Hardware.
After looking for a good place to put the toggle switch and phone jack, I decided to go under the carry handle (when it is down). Since this player comes apart in three main chunks, putting them anywhere else could cause a problem if I have to take it apart again.
I located a place that would have clearance inside, and under the handle, then drilled the holes.
This plastic was really thick, and the jacks wouldn't go all the way through, so I used a larger bit to do a type of countersink on each hole, making the hole larger on the topside, and thinning the plastic so that I could fasten the jack and the toggle with the supplied hardware.
Step 4: Hooking Up the Hardware
After both items were mounted I unplugged the connector that goes to the leaf switch and to the tape player motor. I separated the motor wires, cut the red wire and hooked it up to the toggle switch.
The next step is to de-solder the wires coming from the tape head and connect them to the phone jack, then connect the wires from the phone jack back to the board that the tape head wires were soldered to.
The tip of the line in jack is the Left positive, the next band down is the Right positive, and the rest of the jack is the ground.
The picture of the back of the phone jack box shows the diagram, and I have the area on the right labeled as follows:
1 = Ground
2 = Left Board
3 = Left (head)
4 = Right (head)
5 = Right Board
I soldered all the wires in place and tested the system:
Step 5: It Doesn't Work.... Maybe... Wait.. Success !!
The sound is terrible ! It's all broken and fuzzy with distortion.
I tried turning the volume on the mp3 player to 1 and it was still distorted.
Next I tried another mp3 player - with the same results.
I checked the wiring again and it was all fine.
Then I started to comb the boards for a line in or L, R marking. All attempts at getting a signal through sounded distorted.
I didn't want to add a resistor to each channel because of possible sound quality issues, so I decided to check the IC on the tape player board.
I went here:
http://www.datasheetcatalog.com/
and discovered that the IC was a system preamp for the tape deck.
The IC is a Toshiba TA2068N - here's a link to a PDF datasheet (2019 update!)
I got the datasheet and found 2 pins that gave a really good sound for input.
(pins 18/Right and 20/Left)
It was a tough solder either way, but I chose to tap the wires on the top of the IC.
It went pretty well and the wires are pretty stable. If I get a chance to get a hot glue gun I'll add some to make sure the wires stay put.
I left the toggle for the tape player motor, since it does kill some noise.
After that I put the box back together and plugged my mp3 player into it. It sounds great !
It ended up that the closed circuit phone jack didn't get to be fully used (nothing is connected when there is nothing plugged into it). That's OK, though, because it was the only type Radio Shack had at the time !
57 Comments
3 years ago
Hi! I am trying to do a similar thing with a car radio. I was wondering, you mention pins 18/Right and 20/Left, but what about the common pin? I am not sure if the general ground from the power input is the same as the ground of the audio signal.
Reply 3 years ago
I'd pull a ground from the board if possible, from the audio board, or near where the IC is at. I usually avoid getting ground from a power input as you can get noise with audio.
Good luck! Let me know how it goes!
Reply 3 years ago
I did a lot of testing and so far no luck. Connecting to the tape deck output was a failure, I got audio but I think first of all the cable I used had a semi short, and second the audio was very distorted. Seems that this was kinda the same as with yours, I used an input which was before the preamp. Next I ditched the cable and went for bluetooth straight to the amp chip, but that failed as well. It appears there was a volume control unit before that, so now I will try to go after the tape preamp but before the volume control & final amp. Also I took power from a 5v regulator source for my bluetooth module, but it appears that that part is always on, even when no key is inserted in the car. So that isn't great. Now gonna try a 12v to 5v step down module on the tape motor with a big capacitor to have some buffer power and idk maybe some filtering as well. So hopefully it will run when you insert a dummy tape and stay on for a short while after it so you don't instantly lose connection when the car stalls or idk. Sorry for the long story ;)
Reply 3 years ago
Hi,
Wow, it sounds like your project is quite a bit more involved than my boombox. I've had limited success with car audio. I was trying to add a line in to a stock ford truck radio, and once I got it apart, all the IC's had either ford or nonstandard part numbers so I couldn't get a datasheet on any of the IC's.
I ended up retiring that project and bought a better stereo.
Anyway, hope you get it working!
4 years ago
Thank you, I was not certain whether pin 20 was left or right. Whoever is wondering the IC is Toshiba TA2068N Pin 20 is left input Pin 18 is right and pin 7 is ground. Now it is time to dust off the soldering iron and get to work.
Reply 4 years ago
Hi,
Thanks for the interest!
I discuss the IC, pins, and datasheet in the last part of the instructable.
Hope you got it working!! :)
5 years ago
Did this with an old Technics box. Works ok with the line-in feed onto the output lines of the pre-amp chip, but doesn't sound completely clear, almost like certain frequencies are being clipped by something. I might try shifting the ground and see if that helps. It's not easy to get to though, as it's buried under the CD mechanism.
Reply 5 years ago
Yeah, sometimes you have to dig a little to get it to work right. Also, make sure the signal you're putting in is very low if possible - usually when you hijack an input, it's looking for a weaker signal... Good luck!
Reply 5 years ago
Another hour or so tracing back towards the power amp, and I came across 2 terminals marked "tp-r" and "tp-l" Have a wild guess what they stood for! Never mind, lesson is to have a proper look at the board before you start. Works great now.
Reply 5 years ago
Nice! Glad you got it working!
Question 5 years ago
BUENAS, PERO SI NO TENGO LA CASSETERA SOLO TENGO LA PLAQUITA COMO SERIA LA INSTALACION ,YA QUE TIENE 4 COLORES (NEGRO-ROJO-BLANCO-AMARILLO) , EL MOTOR SI LO TENGO CON SU RESPECTIVO CONECTOR, O TAL VEZ EN LA TARJETA MADRE SE PODRA SACAR UN AUX PARA CONECTAR EL CELULAR, TENGO EL MISMO MODELO DE GRABADORA Y SOLO LA TENGO FUNCIONANDO EN RADIO, APARTE CUAL ES LA POLARIDAD DE ESTE CABLE PARA CONECTAR SIN NECESIDAD DE LA FUENTE ORIGINAL,Y CONECTAR A FUENTE ATX POR EJEMPLO. DEJO LAS IMAGENES. MI whatsapp +593993460463.. EXITOS Y BENDICIONES DESDE GUAYAQUIL, ECUADOR ( NO SOY EXPERTA PERO SOY AFICIONADA NIVEL 5,JIJIJIJI)
Answer 5 years ago
Hola, estoy usando Google translate para intentar responder a tu pregunta.
¿Estás diciendo que no tienes todo el sistema, solo las partes de las imágenes?
No tuve suerte usando el cassette desde el cabezal de la cinta. Terminé obteniendo una hoja de datos para el IC y encontrando las entradas allí. Ese IC en su imagen parece que podría ser el indicado, pero no puedo leer el número en él.
6 years ago
Hello 2017!
Just because this instructable is now 10 years old doesn't mean it's not useful!
I check the comments now and then, and update things that aren't clear.
Good luck wiring up those old boomboxes - I'm seeing more and more of them around with dead cassette decks (likely belts), or CD players - so now you can get them super cheap!
6 years ago
We're not alone in this world! I was wondering about adding an input to my old boom box. Finding this guide was great, but finding out that my boom box was the same as yours was incredible! Thank you! Indispensably helpful.
Reply 6 years ago
I'm glad you liked it!
So many boomboxes, so few line in's. :)
10 years ago on Step 5
on the subject of the belt breaking and autostop turning it off.. i wasn't sure how autostop worked, so I assumed it worked like your''s must, so I unplugged the motor and it still works fine I tried to listen for the motor noise you mentioned but I could not tell the diff with or w/o the motor running (during silence between tracks) there is some noise but not from this motor. I don't need to play tapes, I have tapes, just will never play them again... i'll leave it disconnected.
Reply 10 years ago on Step 5
drewoj,
Glad you got it going! This little rig has worked well for me, and it kept another boombox out of the dumpster.. Glad to hear that you didn't have to keep the motor running and / or put a new belt on the tape drive to keep it playing!
Just thought about this... correction, I hit play on either tape deck and it's enabled... makes sense...
Yo, TheRealAnubis... you the Man (or Woman)!!! I knew this could be done! I just didn't want to figure it out myself!! I've been in software dev for almost 20 yrs but roots are in electronics.. I did this mod to a vintage JVC boom box model PC-XC30. I wrote down the numbers of the ICs I could see and luckily the most accessible one was the cassette preamp! the chip is LA3246, this one is for dual tape deck boxes, but the technique is the same. found the preamp out on pins 4 & 17, top soldered the new audio in to those on the IC and audio common to gnd in the unit. Works like a charm. I just hit play on the right side tape deck and listen to music from my tablet. That is until the tape drive belt breaks and it auto stops. Then I'll need to think.
thanks much! Drew
10 years ago on Introduction
it did work pretty well. i hooked the cables on the amp (IC302), on the pins 8 and 13 if i remember correctly. i don't want to open the thing again to check...
if those don't work you can to hold the cables on different pins until you get a signal, and then solder them in place. this is what i did, but be careful though...
the ground is important too. it worked best in my case with the ground cable from the cinch socket soldered on the outside of the metal bracket where volume control is located (the main ground on the board didn't work for some reason).
the signal is amplified so much that you have to make sure that the volume is set to zero on the boombox, and as low as possible on your source. you then turn 'on' the radio and you should be able to hear your favorite tunes coming out this amazing little device!
hope this helps.
