Introduction: Adding an ATMEGA328P and Real Time Clock to an Existing Project
This was an existing project i had made some time before.
An 8 X 10 LED matrix.
So it is not a complete build, just showing the add on
I have added to the 8 X 10 LED display a micro-processor, the ATMEGA328P running at 8MHz internal clock with Arduino bootloader.
Also a DS1307 Real Time Clock.
You can also see the programming header installed.
Supporting info:
here
here
Supporting info:
here
here
Step 1: Programming
Step 2: Pin Connections
From the 74HC595 shift register to the 328P micro-processor the pins to connect are:.
Pin 14 to 15
Pin 12 to 17
Pin 11 to 16.
From the CD4017 decade counter to the 328P micro-processor the pins to connect are:
Pin 15 to 18
Pin 14 to 19.
Pin connections for the RTC to the 328P ,icro-processor are
SDA to pin 27
SCL to pin 28
Ground and VCC +5v will need to be connected as well.
Pin 14 to 15
Pin 12 to 17
Pin 11 to 16.
Pin 15 to 18
Pin 14 to 19.
SDA to pin 27
SCL to pin 28
Step 3: Code
This is the code i used.
I couldn't copy and past so it is in a attached file.
