Introduction: Adding Antenna to a Mini Wi-Fi Receiver
Hello
Firstly, this is my first instructable and english is not my native language. Because of that please forgive my faults.
Well, tis instructable is about how to add an antenna to a mini wifi receiver. It's not very hard but you will need some basic abilities like soldering. Shall we start!
Step 1: Opening Your Receiver.
I bought this one from eBay it was around 5$. And i accidently pulled it as hard. And i realize that it can open and cloase. Thats all. And just try to pull it. If you can't open it with just pulling, try some sharp materials.
Step 2: Find the Antenna of Your Receiver.
Well it should be something like a green cable which is looking like "s" letter.
Step 3: Engraving the Antenna
if you find the antenna, now you should engrave it to solder it. I used a needle to engrave. If you want you can use a knife or a sharp thing. Just engrave it until you see the yellow or white metal.
Step 4: Soldering!
Soldering to a little place can be hard because of that be carefull while soldering. Do not hurt yourself, also do not hurt the receiver.
Step 5: Make a Hole for New Antenna.
make a hole to plastic. Now here is the thing that you shouldn't do: Dont make hole with your solder machine because it doesnt smell good and its a little bit boring to clean it from soldering machine.
Step 6: Prepare It for Closing.
Well i used hot glue to stabilize solder inside. But after i realized that i used too much hot glue for this. And i tried to make a few millimeters longer.
Step 7: Finish!
It can be a little bit ugly but do not worry about that because its working 3 times better than it was.
