Introduction: Adjust Bandsaw Blade Tension With a Guitar Tuner!
Tuning a guitar is simple - You just turn the tuning keys until you get the right note. Tuning a bandsaw should not be any more difficult, right?
There's just one small problem: you have no idea how it should sound :D What you know instead (in most cases), is the value of desired pressure in the blade to get the best performance.
OK...so what? Well, Here's how you can use some simple math to determine the proper tension of a bandsaw blade using nothing but your ears (okay, and maybe a guitar tuner).
Check the video for a more musical explanation :D
You can also check out my site with a bit more info: http://www.cactusworkshop.com/2016/11/set-tension-...
Step 1: Understand the Basics: How Do Guitar Strings Work?
There is a simple equation that establishes a relationship between the frequency of a stationary wave in a vibrating string (or blade in our case) and the tension applied to it.
That equation is called: the string vibration equation (find the formula in the picture) f=sq(T/μ)/(2L)
MATH! Don't panic. It basically says that the frequency of the sound you will hear, depends on:
- T: Tension (YAY!!)
- L: Free length
- μ: Linear density of the string (or blade) : mass per unit length
Tension is self explanatory: In the case of a guitar, you modify the tension of a string with the tuning keys and get the free string note.
Free length is simply the distance between the ends of the string. This is the portion of the string that is allowed to vibrate. You can produce different notes by modifying the free length - pressing the string against different frets on the fretboard.
The linear density is what makes the strings sound different from eachother while keeping tension under certain levels - You don't want the neck of your guitar broken or bent . Thicker strings (and thus, heavier) will produce lower notes and viceversa.
Step 2: Apply the Theory to Your Bandsaw
Now let's forget about frets and apply the theory to the bandsaw:
- The linear density is just the weight of the blade divided by its length.
- The free length will just be equal to the distance between wheels.
- The tension is usually given by the manufacturer. You can also find recommendations for most kinds of blades online otherwise. If you find a pressure value, you just have to multiply that pressure by the cross section area of the blade to turn it into a force.
Applied to my case, step by step:
Linear density: I just took a (not so precise) scale and measured the weight of the whole bandsaw blade. Turns out it's just about 22grams (0,77 ounces) Regarding the length, I just trust the blade manufacturer and use 1425millimeters (or around 56 inches).
Free length: pretty straightforward. I used a tape measure to get the distance between centers of the wheels. I did this when the blade was already a bit tight so it doesn't change much during the rest of the tensioning. The free length in my case is 396mm (or 15 5/8 inches)
Tension: I found 14500psi would be a good value for my blade. That is around 100MPa. Then I measured the cross section thickness and length in the blade throat (between the teeth), which is the weakest point of the blade. After all, the teeth are barely under any tension unless they are cutting.
After measuring in several throats, I concluded the section was 4.65mm x 0.3mm. So, 100MPa x 4,65mm x 0.3mm provides a tension of 139.5N ≈ 140 Newtons (or ≈31,5 pounds)
Step 3: Calculate and Find Your Frequency!
Now we just plug in the numbers and complete the equation. In my case I got a frequency f=120 Hertz
So, you have to tighten the bandsaw blade until it vibrates at the frequency you got. Pretty simple. Just take your smartphone and download a free guitar tuner app (I used DaTuner lite if you are interested) or anything that can read frequencies through the microphone. Adjust the tension until you get it right. And that's it. You are done!
Step 4: Mind the Harmonics!
There is something else you need to consider: harmonics. Basically, when you pull a string, it doesn't vibrate only in one way, but in several ways at the same time. These are called vibrational modes or overtones. As the wavelength reduces by 1/2, 1/3, 1/4... the frequency is multiplied by 2, 3, 4, etc.
So your string is probably vibrating with all these waveforms at the same time. But you don't need to know all of them, and their amplitude (That's called Fourier analysis). You just need to know the fundamental one, which is the first one.
Why am I telling you this? Because usually your guitar tuner will be clever enough to find the fundamental one, but depending on how you pull the string, you might get it confused and have it showing a harmonic instead of the fundamental . For instance, my frequency is 120Hz, but sometimes the tuner reads 240Hz (2nd harmonic) and then it stabilizes back on 120Hz. Nevertheless, if at some point I found a 60Hz reading, that means that 60Hz was the actual fundamental frequency of the blade, since the fundamental is always the lowest one. Keep that in mind! On the other hand, If my tuner hadn't stabilized on 120Hz I would have thought 240Hz was the fundamental frequency, and thus, that my bandsaw blade was much tighter than needed.
15 Comments
6 years ago
Very clever
Reply 6 years ago
Thanks!!
6 years ago
You'd think a B# would be better. LOL pun (B-sharp). Anyway, I'll try this. Darn clever.
Reply 6 years ago
hahah thanks!
6 years ago
Excellant idea!!!!!
Reply 6 years ago
Thank you very much!!
6 years ago
I will probably never use a tuner for my bandsaw, also because it is a tool I don't have. However I really like your idea... it sounds crazy! Super!
Reply 6 years ago
if you have a smartphone - you can download a tuner app. Many for free.
Reply 6 years ago
Thank you very much! maybe one day you'll get one! :)
6 years ago
I don't have a bandsaw (yet) but I can see how this would work really well with my scroll saw. And I only use one type of blade, so I should be able to find the note and stick to it. Might even work for my bow saw. Thanks for the great tip.
Reply 6 years ago
Great! let us know how does it work for you! :)
6 years ago
Okay, but the frequency will change depending on the metal composition, width, and tpi. So the typical way is to adjust so the blade can't easily be moved with your thump applying side pressure. And that seems to be working perfectly for me over the years. I have never ever had a blade break yet. And I have used a lot of different blades depending on what I are cutting. And my setup doesn't have any blade wondering, whether re-sawing wood or basic flat wood curve cuttings. JMHO
Reply 6 years ago
okay, but you don't need to mind metal, width or tpi. It only depends on weigth per unit lenth. Of course those 3 properties participate in that linear density, so yes, there will be a specific frequency for each blade. I'm not saying this method is better than yours, it's just a different one. Whatever works for you is more than fine :) I just like to put numbers to "can't easily move" which can be very subjective. Thanks!
6 years ago
Amazing thinking outside the box, great explanation of the theory too. Well done
Reply 6 years ago
thank you! :)
