Introduction: Adjustable Depth Stand
This an adjustable depth stand, for your monitor or whatever you want.
From 312 mm to 356 mm adjustable depth and 80mm height (and is designed for a 16.8mm or less height top surface)
Yo need a 3D Printer and... that's all!
Well... and a wood, plastic or anything useful as the tand surface
Step 1: Print the Parts
TO PRINT TIGHTING SCREW AND BUSHES
- Layer height: 0.12
- Infill: 100% (we need a strong partt)
- Supports: No
- Use Skirt,for the screws, is not necessary but depending your bed could've some issues without it.
TO PRINT SUPPORTS MALE AND FEMALE
- Layer height: 0.24
- Infill: 10% (better use 4 wall-width count)
- Supports: No (Are included with the STL) Printing the "Male" be carefull with the orientation of the included supports, that are touching the bed.
Step 2: Assemble the Parts
Remove the supports and rafts and that's all
Is quite easy, check the video if you've any doubt
