Introduction: Adjustable Leather Bracelet
Boho style bracelets are all the rage these days. This Instructable will show you how to make a simple adjustable boho-style leather bracelet in minutes.
Step 1: BoM
Leather cord (1mm, 1.5mm, 2mm. Amount depends on your wrist size)
Beads (at least 1 bead has to be large enough to accommodate both cords)
Charms
Step 2: Measure
The average female bracelet size is between 6-7". My wrist is 6.5" wrapped snug. I want to accommodate for knots, etc. so I measured out a couple extra inches and cut about a 12" cord.
Step 3: String
String the bracelet with the beads you want and then move them to the center of the bracelet.
Tie knots on both sides of the beads.
Step 4: Knots
Slide (at least) one more bead onto one end of the bracelet and then tie a knot at the end of the cord. The bead should be large enough to accommodate both cord ends.
Slide the other cord through the bead and tie another knot. These ends are how you will loosen or tighten your bracelet!
Step 5: Wear!
Try out your bracelet and if you feel the ends are too long, undo the knots tie them further up the bracelet. Cut off the excess.
