Introduction: Adjustable Shelve Box
This project is about a box which can be used to store things and also can used as decorative shelf. This can be used by placing it on a horizontal surface to store things and by hanging this on wall to use this as shelve . Interesting part is, inside walls can be adjusted according to our required size of object. This box size is 60*15*42 cm. This can be dismantled easily and transported anywhere you want. Hang this on a wall where you want shelve. You can place this on your table and you can put books, laptop, pens accessories …..etc.
Cardboard size of 70*55*45 cm
MACHINERY :
General cutter
Wood Working Scroll Saw
Step 1: DESIGN
All the parts are designed in tinkercad. Designs are made for a box of size 60*15*42 cm. box. Just one piece of every part is required except part2 and part 9. Two pieces are required of part2 and 5 pieces are required of part9. So, There are total 14 parts in this project.
Step 2: MANUFACTURING THE PART
According to design, I drawn the 2d view of every part on cardboard. After drawing the view, the parts are extracted from cardboard by cutting them by using Wood Working Scroll Saw. All the parts are made in the same way. You can replace this step if you have a laser engrave machine or another similar machine. Due to less resources I have chosen this step.
Step 3: ASSEMBLING
Firstly, around the part1 attach part2, part3 and part4 at their respective place in respective order.
Next insert inside walls in the box as your requirement. By interchange the inside walls we can get up to 16 different shapes. Place the box on horizontal surface or hang it to a wall.
Step 4: PLACE YOUR THINGS
Here you need to place the box as your requirement either vertical or horizontal. Now you can put your objects in the box. Parts can be easily dismantled and can be moved to any place. Inside parts can be replaced or moved as per your requirement.
