Introduction: Adrianino. ATtiny 1614. UPDI.
The following project was born with the idea that electronics is very easy to learn and modular at the same time. Although I have already finished my Fab Academy, I am still researching. Speaking with my instructors Nuria and Pablo, I told them that I wanted to continue working on the Hello World project, but I was not satisfied with making a board for each sensor or actuator.
So I decided to make a board with the ATtiny1614, where I could use the maximum pins for the inputs or outputs; that had external power; I2C connection. The idea is that a student can test as many sensors as possible, become familiar with electronics and programming little by little. And the Adrianino was born. Furthermore, I wanted to go one step further and place a VCC pin next to the UPDI programming pins, which I will explain later on how it works. This version of Adrianino has been updated for the new Serial-UPDI converter.
Step 1: Features
- This board has FTDI and UPDI + VCC connection to program it without the need for external power (or the FTDI).
- It contains a voltage regulator to power the board with a power supply (9V battery).
- It has another 9V power connection to for example power a DC motor driver.
- Then there are 4 outputs or inputs with VCC and GND on each side to be able to connect different inputs or outputs.
- On the left there is an I2C connection to connect an LCD, OLED or a sensor that uses this communication.
- There are 3 outputs or inputs at the bottom and with a GND pinout.
- There is an LED and an integrated button, which will help us to test that the microcontroller works with a simple program.
- Through the FTDI connection we can read the data from the different sensors through the Serial.
Step 2: Datasheet
ATTINY1614
As we have looked at the graph, there are more microcontrollers within the tinyAVR-1series family. Another ATtiny I use is the 1614. I combine the Datasheet image with the one from the SpenceKonde website on the ATtiny1614.
- 14 pin package.
- Two internal clocks 16 and 20 MHz.
- 16 KB Flash Memory.256 B EEPROM.2 KB SRAM.
- Maximum voltage: 6V; minimum voltage -0.5 V.
After looking at the basic features, you will find the pinning of the microcontroller.
Step 3: BOM and Schematic for Adrianino
This is the schematic where you can see all the components. More information here.
Step 4: Board Design
Here you can download the Eagle files and the PNG's. Here is a sample of the PNG's, traces and cutting lines. The files are for milling with a CNC machine.
Step 5: UPDI + VCC Module
You can find the files to create your Serial - UPDI + VCC converter here.
Step 6: Operation
The connection is very simple, we only need the FTDI-USB and we connect the UPDI + VCC module to the board, in this case to the Adrianino that has the three pins (UPDI + GND + VCC).
Step 7: Programming With Arduino IDE and Windows.
Video Tutorial
Step 8: Inputs and Outputs.
You can connect different sensors and actuators. In the following video you can see several examples. In this link you can find more documentation.
