Introduction: Adventure Time Earrings or Necklace
My best friend loves Adventure Time, and admittedly, I love it too. She also loves earrings, and makes jewelry like crazy, but often for other people and never herself. I decided to combine her loves and make her some Finn earrings.
I made it at TechShopSF!
Step 1: Materials
For this project I used:
Epilog Laser Cutter
24"x24"x1/8" plywood
CorelDraw
4mm and 6mm Silver Jump Rings
Earring Posts and Back
18" chain
Claw clasp
2 small tipped pliers
I had to go to a specialty store to find the 1/8" plywood, so call around before you run off to Home Depot or Lowes.
Epilog Laser Cutter
CorelDraw
18" chain
Claw clasp
Step 2: Masking Your Wood.
I have learned from cutting wood with lasers, that smoke can burn your wood, and be difficult to sand out. Applying masking tape to both sides of your material does not solve this problem, but it helps a bit. I used 24" wide masking tape on a roller to skin my plywood, but if you can't find that at your hardware store, just get some 3" tape and make multiple passes.
Cover both sides, smoke can damage both the top and bottom layer of the plywood.
Step 3: Draft a File.
I did an image search for "Finn Adventure Time" and found a Finn I thought I would be able to replicate in a digital drafting program. I used CorelDraw to generate the file.
All of your lines that you want the laser to cut must be set to hairline thickness in Corel, any thicker lines will be etched. All of the lines I wanted etched, I set to .5 pt thickness. I extended, or bled, my etch lines beyond the cut lines so that they would look cleaner.
Each of the holes is .1 inch diameter, which is just big enough to get jump rings through.
I used the Pen tool to draft the form, the shape tool to tweak the form, and then the circle tool to make the holes. It took me about 15 minutes to trace the original Finn, and make my own. (but I also attached the file)
Step 4: Cut Your Pieces.
You may need to make adjustments, so don't cut a lot of them at once. My first pass was not so successful, and I realized I had to move some of the holes around so that the limbs didn't break. It took me two test cuts before I could cut an army of Finns.
Step 5: Assemble Your Character
I set out the parts, and then figured that I needed 8 jump rings per character, and then 1 jump ring to connect to the top of the figure. It takes a bit of patience, but split all the jump rings, and then thread them through their respective holes.
Step 6: Attach to Hardware.
I decided to make earrings and a necklace, so I made two Finns for earrings, attaching them to posts, and a necklace charm.
Step 7: It's Adventure Time!
That's it! Take your new wiggly buddies on your own adventure, but be careful - once your friends figure out you know how to make stuff like this, you will get a backlog of orders.
