Introduction: Aeon Nova 10 Elite Laser Cutter and Engraver
About: MADE, the latest innovation of its parent company Hacker Lab, is where dreams become a reality. For over a decade, Hacker Lab has supported countless individuals to “BUILD CODE UNITE”. At MADE, we live by the …
Today we are using our Aeon laser to go through the process for cutting and engraving on a piece of wood.
Aeon Laser Nova 10 Elite
Air Compressor
Ventilation fan
Blank wood
Step 1: Air Assist
Turn on the Air Assist Master Switch.
Step 2: Laser On
Turn on the laser on by turning the key(located on right side of the laser)
Step 3: Ventilation
Make sure ventilation is on and fully powered.
Step 4: Place Material
Place Material on laser bed
Tip: the bed size is 28” x 39”, so make sure material is no larger
Step 5: Jog
Position laser head over the top of your material and use Focus button to auto-focus the laser to your material.
Step 6: Set Origin
Move laser to approximate origin point and press origin
Step 7: Frame
Using the “Frame” button to confirm the size and location of the job.
Tip: the box button will outline the frame of the job you just sent to the laser
Step 8: Checklist
Before Pressing Start Double Check the Checklist
  • Laser is on
  • Air Assist is on
  • Workarea is clean
  • Material is not on the banned list
  • Water is on hand, in case of small fire
Step 9: Start
Start your job!
Tip: Keep your hand over the power button if you see anything going wrong.
