Introduction: Aging GIF Animation in Photoshop
In this tutorial we'll create an aging GIF animation using a free online aging filter and Adobe Photoshop. You will learn what settings to apply in order to create a rapid aging gif or a slow one. I will also show you how to create a reverse aging GIF.
For this tutorial, you'll need the following resources:
- A photo of a young person
- An aged version of the same photo
- An AI aging tool
- Adobe Photoshop
Step 1: Prepare Your Images
To create this aging GIF animation we need two images, one young and one old. You can do this in Photoshop but it is best to use an online AI Aging Filter to generate an old version of your young photo.
Step 2: Generate the Aging Face Image With AI
I will use this face aging online free tool. Upload your photo and then choose to make the subject Younger or Older.
You have to save both young and old images in separate files. Make sure that the two image have the same width and height.
Step 3: Open Photoshop
Go to File > Open and load both images as separate layers in one PSD document. Name the layers Young and Old.
Step 4: Open the Timeline Panel
Go to Window > Timeline to enable animation tools. Click Create Frame Animation in the Timeline panel.
Step 5: Create Animation Frames
Add the young image as the first frame. Duplicate the frame and change the layer visibility to show the old image.
Step 6: Add Tweening for Smooth Transition
Select both frames, then click Tween (icon at the bottom of the Timeline panel). Set the number of frames (e.g., 10-20) for a smooth fade effect.
Step 7: Adjust Frame Timing
Set each frame duration (e.g., 0.1s for smooth playback). Click Forever in loop settings for a continuous animation.
To create the reverse aging GIF, duplicate the first frame and move it to the last position. Then, select the last two frames and click on the Tween icon again. This will create a smooth transition from young to old and vice versa.
Step 8: Export As GIF
Go to File > Export > Save for Web (Legacy). Choose GIF format, adjust quality, and click Save.
Step 9: In Conclusion
This is an easy way to create an aging GIF animation using Photoshop. Try this effect for your own photo and show me your results!
