Klaxon/Ahooga Horn Lubrication
Intro: Klaxon/Ahooga Horn Lubrication
This is my first instructable and hope it helps other with similar problems.
I bought a North-East Electric Company ahooga horn from an antique store and after taking it home I realized why it was there in the first place. It wouldn't make the ahooga sound it was more like awoowa. I took it apart and lubricated with light oil and it worked! Ahooga! But hold on why have I made this instructables? It didn't last long before it was back to awoowa. In this instructable I'll show you how to tear down an Ahooga horn .
STEP 1: Tear Down
You need a ratchet or wrench and a screw driver.
Remove the bolts around the horn and take the motor cover off. Next remove the horn and the motor assembly
STEP 2: Greasing
I used white lithium grease and grease the tuning screw, and the bushings. I then ran the motor but you could spin the motor by hand and then wiped the excess grease so it doesn't splatter all over the place.
Correction, after using it for awhile and with it getting cold I have found the grease is too thick and now I use a common 3 in one oil on all the parts except the diaphragm gear (use grease on that). I cleaned off the grease and applied the oil in the same spots where I greased.
STEP 3: Optional
I cleaned the copper thing at the bottom of the motor because it had a sticky residue.
STEP 4: Reassembly
Put it back together and enjoy a well lubricated ahooga horn.
Checkout the motorized bicycle here and feel free to comment
17 Comments
JD Grayman 9 years ago
truuuuuuuuuuuust 9 years ago
Oh my god, what an idea. I have a '99 I30 and don't care for the stock horn. Now I'm tempted!
szvenigorodsky 9 years ago
Ghost Wolf 9 years ago
I just finished it here
Divisible_By_0 9 years ago
yes you should do one on the motor bike
I just completed it here
nsimpson4 9 years ago
I made the changes thank you!
seamster 9 years ago
Very nicely done! Thanks for sharing this.
I would love to have one of those horns. I can think of so many fun uses!
I already have put it on a bicycle :D
bpotts2 9 years ago
See a motorized bicycle with ahooga horn
Phil B 9 years ago
Klaxon or ah-oooh-gah horns can be purchased new various places. Amazon has them. I bought one new at K-Mart back in the 1980s. You do need to tune them by adjusting a screw with a nut on the diaphragm. It took me several attempts to get it right.
For this one there is a screw on the back (it's the center one) that advances the motor into the diaphragm and is quite fussy :P
