Introduction: Aid for Deaf
Hi there, Welcome to my first instructable, in this instructable I am going to teach you how to make a device that displays whatever we speak.
It would be helpful for deaf people to understand what we speak.
Step 1: GATHER YOUR MATERIALS
Arduino Uno R3 or you can use arduino nano (Both of them will work, but I will show you with Arduino Uno)
- LCD Display
Android Phone
Cardboard
Metal Strips (or you can use velcro)
Step 2: GATHER YOUR TOOLKIT
- Gluegun and gluesticks
- Screwdriver / Double Sided Foam Tape
- Your skills and yourself
Step 3: UNDERSTANDING THE CIRCUIT DIAGRAM
In the circuit diagram you can see the connections and you can do it yourself. It is pretty easy.
The circuit: //gnd refers to ground
LCD RS pin to digital pin 12
LCD Enable pin to digital pin 11
LCD D4 pin to digital pin 5
LCD D5 pin to digital pin 4
LCD D6 pin to digital pin 3
LCD D7 pin to digital pin 2
LCD R/W pin to gnd
LCD VSS pin to arduino gnd
LCD VDD pin to arduino 5v
Bluetooth 5v to arduino 3.3v
Bluetooth gnd to arduino gnd
Bluetooth Tx pin to arduino Rx pin
Bluetooth Rx pin to arduino Tx pin
Battery +ve to arduino vin pin
Battery -ve to arduino gnd pin
optional (if you want to adjust contrast) :-
10K resistor between 5V and ground
potentiometer (pot) to LCD VO pin (pin 3)
Step 4: GETTING THE CODE
Make sure to disconnect Bluetooth Module before Uploading the code.
// include the library code:
#include
LiquidCrystal lcd(12, 11 ,5 ,4 ,3 ,2);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// initialize the serial communications:
Serial.begin(9600);
void loop() {
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
Step 5: BASE COMPLETED!!!
Make a rectangular base with cardboard and attach velcro to it. Attach the final circuit on cardboard with Gluegun / Double Sided Foam Tape.
CONGRATULATIONS!!! your base assembly is finished.
Step 6: Download My App
- Grab your Android phone and download my app.(Or you can make it on your own)
- Install my app.
- Go to bluetooth settings on your phone and pair with your bluetooth module (Its Default name is HC-05 / HC-06 and pin is 1234)
- Open my app and click on "Connect to Device" and then select your bluetooth module's name.
- After it is connected, you can Tap on "click to send" and say something.
- It will be displayed on the LCD Display.
Step 7: Bye Everybody!!!
Congratulations!!! You made a Aid for Deaf!!! You can now give it to someone needy. If you can't make it or have any Doubts, feel free to ask as it was my first instructables. Please comment below to help improve my skills.
