Introduction: Air Boat
Hi guys i am kushal from Banjarapalya Makerspace. Today i will show you how to build a Air Boat using simple home waste items.
Materials:
Cola cans with caps
Lamination sheet
Metal strip
Motor
Toy fan
Wire
Switch
Nylon tie cable
AA Battery or 9v battery
Batter holder
Battery cap
Hot glue
Step 1: Take Two Cola Bottles
Take two cola bottles and nylon cable tie then tie it as shown in the image. and make sure you are sticking the bottles with hot glue or superglue.
Step 2: Metal Strip and Motor
Take two 10cm metal strip and motor then fix the motor inside the metal strip as shown in the image with the help of hot glue.
Step 3: Make a Hole
Take a marker pen and make two mark where would you like to fix the motor then, make the hole use any sharp metal.
Step 4: Fix the Metal Strip With Motor
You need to take the metal strip and motor which you already fixed together, then fix it to the bottle as shown in the image with the help of screws.
Step 5: Fix the Wires,switch Toy Fan and Lamination Body
Take wires then fix it to the motor,then take a switch fix it to the wire and lamination sheet as shown in the image.
Step 6: Fix the Battery
Take 4 AA battery then put it in battery holder then fix it on the bottle using battery cap, then give the connection to motor and switch as shown in the image.
Finally your air boat is ready to use.
You tube video link :
