Introduction: Air Chamber for Air Gun
This is how to make an air chamber to use in conjunction with my Pump action dart gun or a air gun
I will put good photos in soon but for now you will have to rely on paint for pics
And ill put in a vid soon
Step 1: Materials
What you need:
1 piece of PVC pipe 35cm by 50mm (or whatever)
2 end caps 50mm HIGH PRESSURE END CAPS because the the weak ones will make the chamber EXPLODE it happened to me.
plummers glue or dam strong glue
car valve or motobike valve
hose fitting
more dam strong glue like areldite stuff (for the bike valve and hose fitting)
se pic
hose fitting
se pic
Step 2: Drilling
get the end caps and drill the size if the bike valve and hose fitting so it is a snug fit
Then glue the craper out of it so its DAMMMM strong
Step 3: See Pic
seeeee picture |
\_/
\_/
Step 4: Building
now glue the inside of both end caps with plumbers glue or equalivent, after the valve and fitting are glued well
then attach end caps to PVC
you can also glue PVC where the end caps go
SEEEE PIC
SEEEE PIC
Step 5: Completion
YEY YOUR, DONE NOW PUMP IT UP usuall to about 120 PSI but be carfull and use safety equiptment you should hopfully gey a couple of shots out of it YEY
JUST CLIP IT IN TO THE HOSE FITTING ON YOUR GUN
see pic
see pic
