Introduction: Air Compressor Bottle Rocket
This is a simple But powerful Bottle Rocket that can go hundreds of feet in the air.
Step 1: Supplies
You will need
- Cardboard
- Painting supplies
- Water bottle
- Tape
- Hot glue gun
- PVC
- Air Compressor
- 1 Fitting
- Cut off Hose
Step 2: Connect the Bottle to the PVC
You Have to make sure that your bottle is on the PVC tight so that it doesn't let the air out.
Step 3: Build Your Cone
Use Card stock or Cardboard Too Build your cone.
Make sure you attach weight to the tip.
Step 4: Make Your Fins
Use cardboard to build your fins in any shape you want.
Step 5: Attach Fins and Nose Cone
Use Glue or tape to attach your Fins and Nose Cone.
Step 6: Decorate Your Rocket.
Paint any designs you want on your rocket.
Step 7: Build Launch Mechanism
Connect Fitting and hose to the end of your PVC Pipe.
Step 8: Launch Your Rocket
Connect air compressor hose to your fitting and push the hose in.
Look at the Video to see mine launch.
Add water into your rocket for the smoke affect.
