Introduction: Air Cooled 2 Stroke Cylinder Head Using Shell Casting
Not Long ago, we decided to make a custom air cooled cylinder for a two stroke engine that we're developing.
We decided to use Shell casting, mainly because we'd never done it before.
Step 1: Patterns and Sand Box
First we CNC machined some patterns and some boxes to hold the sand
Step 2: Shell Sand Mold
Heat the pattern and invert the sand over it. The sand is coated with a thermoplastic resin that binds together and forms a shell. This is used as the mold to pour the aluminum
Step 3: Make the Castings
Pour the aluminum. fettle and shotblast
Step 4: CNC Machining
Machine the Cylinder head to fit your engine
Step 5: Fit on Engine
Enjoy!!
Metal Contest 2017
15 Comments
Question 2 years ago on Step 5
What Engine was this Head for? What do you charge for the Heads?
Answer 2 years ago
It's for a small agricultural engine that we manufacture.
The head costs about USD 6
Reply 2 years ago
You ought to repop some Skidoo/Rotax 2 Stroke Singles Heads and Cases. The Skidoo 277F is also a 277UL Ultralight Airplane Engine. A used 277 Head goes for $50 on eBay. A Rare Expensive Head is the Skidoo Blizzard 292 & 340 Free Air Head $400 if you can find one. The 277F/277UL is (72mm x 66mm) 268.4cc and uses 11.8cr. The 340 Blizzard (36hp) was (78mm x 70mm) and the 292 Blizzard was (75mm x 66mm). 1st photo 277 Head, 2nd 277F, 345 are a 340 Blizzard Engine.
Question 4 years ago on Step 2
Hi, what is the resin composition?
Answer 2 years ago
It's a phenolic resin with a hexamine catalyst
4 years ago
VERY nicely documented.
No, you are making near net shapes by casting, the time to machine the final details is a LOT less than the cost of milling the fins for example.
Question 4 years ago on Step 4
If you have a CNC machine, wouldn't it be easier to use Billet Blanks or Pour your Scrap Aluminum into Blocks and then just Machine them into Heads? Depending on the Size of your CNC Table, you ought to be able to setup anywhere from 3-6 Heads to be machined. You can Cut Flat Raw Stock on a cheap Table Saw with the right Blade. What CR are you using on that Head, and what Bolt Pattern? What do you charge for them in USD? You ought to make some Rotax 277UL(26hp@6250rpms) Single Cylinder Engine parts, Head, Cylinder, Case. Head/Cylinder use's a (4) Bolt Pattern based on a 100mm Bolt Circle. They use 8mm Studs. What CC is your Engine and Hp@rpms? What is it for?
5 years ago
what did you put on top of the casting that burst into flames? Why do you do that?
Thanks
Reply 5 years ago
It's an exothermic hot topping compound. It is sprinkled on the risers to make sure they remain molten till the casting freezes. This ensures a sound casting
5 years ago
Very nice project. Thanks.
5 years ago
Awesome project. You've got my vote.
Reply 5 years ago
Thank you
5 years ago
Interesting project. Looks like you modeled it off a Briggs and Stratton style engine.
Reply 5 years ago
Nope. The starting point was a Honda 2 stroke scooter engine
