Introduction: Air Dry Clay Stamp to Get You Stampin’ in Style
Make an impressive one of a kind clay stamp by using PLUS air dry clay
Materials need:
Pencil or a wooden skewer
Cheese cutter Buttons, stamps or anything with a good texture
Clear acrylic spray to seal
Cooking Spray
Step 1: Shape the Clay Stamp
Pull or cut a piece of clay off of block about the size of a walnut. Without over working the clay, shape the clay into a ball by rolling in between hands.
Begin forming the handle of the stamp by grasping ball in the middle and pulling and rolling a handle or doorknob shape.
Tap the ball end of the stamp lightly on a flat surface to make the stamp work space.
Step 2: Design Your Air Dry Clay Stamp
Take a pencil and make a design in the clay that is deep enough to leave a good impression. At this point, do not moisten either piece as this will make it very hard to remove the pressed in object.
Optional: use a cheese cutter to cut around the stamp to make a more interesting design.
Allow to dry thoroughly. The air dry clay will become lighter in color and will not be cool to the touch. This may take a day or two. Spray the stamp with clear acrylic spray to make it water resistant. Let it dry and then spray lightly with a cooking spray for easy release.
Step 3: Using Your Stamp
Roll out some Plus air dry clay. Stamp the clay. You now have an imprint of your clay stamp.
Use a skewer to cut around your impression and you have a new clay piece to dry and use as you wish.
Created by Karen Lowrey (March 2015); photographs by Suzanne Bardwell
2 Comments
7 years ago
Wow! This is so cool! Thanks of making this!
Reply 7 years ago
Thank you for your kind comments!
