Air Layering
Intro: Air Layering
Air layering plants requires a moist environment for aerial roots to form. Most plants can be air layered and, even if no rooting takes place, the original plant is not damaged by the process since you do not remove the donor material until it has produced roots.
you go to this link to video
https://m.youtube.com/watch?v=FoXH-WuCrxY
STEP 1:
STEP 2: Method of Wounding Woody Plants
STEP 3: Preparation of Soil
STEP 4: Applying Honey
STEP 5: Using a Sheet of Polyethylene Film
Using a sheet of polyethylene film approximately 6" X 12" or 8" X 12", depending upon the size of the plant stem, wrap the ball of soil mixture using the butchers fold (see insert) to secure a tight seal where the two ends of the sheet are joined.
STEP 6: Placing Soil in Cut Part and Tey
STEP 7: Result(new Roots Have Penetrated)
After the new roots have penetrated the moss ball and are visible on all sides, the rooted branch may be removed from the parent plant. The rooting time will vary with plant variety as well as the season in which it is performed.
4 Comments
kurshiukas 6 years ago
Does that work with trees, like walnuts?
R4L 6 years ago
It will work with all rooting plants.
Choose a branch not larger than 5 cm diam.
Mechanical bro 6 years ago
Swansong 6 years ago
That bounced back pretty quickly! My grandmother used to do this with her roses often :)
