Introduction: Air Synthesizer With Color Tracking in 10 Min
About: With Grablo, Anyone can create amazing IoT projects quickly and easily, without writing a single line of code.
This tutorial shows how to build an Air Synthesizer using visual programming blocks. Move a colored ball through camera zones to play musical instruments in real-time—no coding required!
What You'll Build
An air synthesizer with:
  1. Real-time color ball tracking
  2. 5 playable zones
  3. Multiple instruments via Sound Font
  4. Dynamic instrument selection
  5. No coding required
Required Components
  1. Raspberry Pi, BeagleBone, Jetson Nano, or PC
  2. Camera (Raspberry Pi Camera Module or USB Camera)
  3. Speaker (3.5mm audio jack, USB audio adapter, or Bluetooth)
  4. Colored ball on a stick (ping pong ball recommended)
Step 1: Quick Start
  1. Download and install Grablo software on your Raspberry Pi
  2. Connect camera and speaker
  3. Get this project
  4. Open Grablo app in your browser
  5. Connect to your Raspberry Pi and hit RUN!
  6. Adjust color range in Color Picker to match your ball
  7. Change Bank and Preset values to select different instruments
To build it yourself, continue to Step 2.
Step 2: Create Dashboard
Create Project & Dashboard
  1. Go to https://app.grablo.co
  2. Click "Create Project"
  3. Name your project
  4. Create a new dashboard
Add Widgets
  1. Camera Widget: Select your camera to display live video feed
  2. Color Picker Widget × 2: Create "Start Color" and "End Color" variables for tracking range
  3. Input Widget × 2: Create "Bank" and "Preset" variables for instrument selection
Step 3: Logic - Start Camera & Play Notes
Control 1: Start Camera
Start the camera when the project begins.
  1. Condition (Once): Runs once at project start
  2. Action (AI Camera): Create camera, set Orientation to Horizontal Flip, Command to Start, add Color Tracking for 5 Zones
Control 2-6: Play Notes
Play synthesizer notes when colored object enters each zone.
  1. Condition (Compare): ZoneDetected = True, Option = Rising Edge
  2. Action (Synthesizer): Create synthesizer, Command = Note On, Note = C3-G3 (48-55)
💡 Tip: For fastest response, set execution interval to 1ms.
Step 4: Logic - Instrument Selection
Control 7: Instrument Selection
Change instruments when Bank or Preset value changes.
  1. Condition (On Change): Bank or Preset variable, Operator = OR
  2. Action (Synthesizer): Command = Set Instrument, assign Bank and Preset variables
Step 5: Color Tracking Tips
For best tracking results:
  1. Use bright colors: Orange, green, or pink work best
  2. Avoid matching clothes: Don't wear the same color as your ball
  3. Consistent lighting: Avoid shadows and backlight
  4. Fine-tune colors: Use HSV tab in Color Picker, adjust H value for precise tracking
Step 6: Launch Your Project
That's it—you're done!
Launch Your Project
  1. Open Grablo app in your desktop or mobile browser
  2. Select your project
  3. Connect to your Raspberry Pi
  4. Hit RUN and enjoy!
Expected Results
When you run your project:
  1. Camera view appears with 5 zones at the bottom
  2. Move ball into Zone 1: Plays C3 note
  3. Move through zones: Each zone plays different notes
  4. Change Bank/Preset: Switches instruments
  5. Play music by moving the ball through zones!
Step 7: Video Tutorial
Watch the complete build process in action!
Step 8: Expand Your Project
Add more functionality:
  1. Add more zones for a full octave
  2. Create duet mode with two different colored balls
  3. Add visual feedback when notes play
Troubleshooting
No sound:
  1. Check speaker connection
  2. Verify Bank and Preset values (try Bank = 0, Preset = 0)
  3. Check audio output settings on Raspberry Pi
Color not tracking:
  1. Adjust Start/End Color range in Color Picker
  2. Use HSV tab and fine-tune H value
  3. Improve lighting conditions
  4. Avoid wearing clothes matching ball color
Notes playing multiple times:
  1. Verify Rising Edge option is set in conditions
  2. Check that zones don't overlap
  3. Increase Min Area to ignore noise
Sound Font Resources
  1. Polyphone (Sound Font Editor): https://www.polyphone.io/
  2. Sound Font used in this project: https://musical-artifacts.com/artifacts/7293
Resources
  1. Website: https://grablo.co
  2. Download: https://grablo.co/download
  3. Web App: https://app.grablo.co
  4. Docs: https://doc.grablo.co
  5. Support: support@grablo.co
