AirStamp - Interactive Stamping
Intro: AirStamp - Interactive Stamping
Physical stamping is fun. In this project, we want to turn physical stamping into digital display and allow manipulation of the text being display to make stamping experience different and even more cool such as controlling the text size with hand movement and use blowing to erase the texts. The following page will show you how to make a digital text display using physical stamps as input. Let's begin to build AirStamp!
Co-Designers: Yao Yue Yang, Daisy Zhang, Pang Bo
STEP 1: Step 1: Prepare the Materials Required
You will need the following material
- 1x RFID Reader (13.56 Hz, ISO14443A, UART port) https://item.taobao.com/item.htm?spm=a230r.1.14.9...
- 30 x 2.5mm RFID tags (13.56 Hz, ISO14443A)https://item.taobao.com/item.htm?spm=a1z10.3-c.w4002-1036438215.13.oMgUS9&id=43794432412
- 2 x IR Distance Sensors GP2Y0A41SK0F https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- 2 x Arduino Micro Boards https://item.taobao.com/item.htm?spm=a1z10.1-c.w4... (We used another Arduino board but the board broke. This is another board our classmates purchased with good quality).
- 2 x Printed Circuit Board 7cm x 9cm Universal PCB Board https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- 8 x NeoPixel Mini PCB WS2812B https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- 5 x 27mm Piezoelectric Meters https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- 2 x 3mm MDF board (45cm x 60cm each)
- 2 x 1mm Transparent Acrylic boards (20cm x 30 cm each)
- 1 x Black Sway Cloth or Bubble Wrap 125cm x 90cm
- 2 USB cables
- 1 iPad Mini (or any tablets but you may need to adjust the dimension of the display box accordingly)
- 1 Computer
- 1 Ink Pad (any colour of your choice)
- 1 power bank
- 22 AWG Hook-Up Wires (2 different colours to differentiate positive and negative)
- 4 x resistors (Brown, Yellow, Black, Black, Brown)
- Wood Glue https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- Laser Cutting Machine
- Black Tamiya Spray Paint https://item.taobao.com/item.htm?spm=a1z10.1-c.w4...
- Black Sway Cloth 9"x9"
STEP 2: Step 2: Solder Piezoelectric Meter
Solder the all Piezoelectric Meters to two different colour of wire to differentiate positive and negative as image below.
Solder a resistor to the other end of the two sides of the wire connected to the Piezoelectric Meter. Then solder another 2 pieces of wire on the other end of the resistor as image below.
The end product would be like this.
Solder 5 sets like this. 4 sets would be for the Piezoelectric Meter to detect the pressure of stamping. The last set is to detect air blow pressure.
STEP 3: Step 3: Solder Neopixel LED Light
At the back of each Neopixel LED, there are 6 connecting area (labeled below). Connect a wire on each connecting area.
Same as above, connect 4 lights together. Leave the wires on the 2 ends on each side loose to be connected to the Arduino board in Step 4.
Repeat the above. Solder 2 sets of 4 lights which will be placed on each side of the Display Text Box.
STEP 4: Step 4: Solder the Arduino Board With the Sensors & Actuators
(1) Prior of soldering the sensors and the LED light to the board, make sure the following are done:
(a) Solder 2 separate sets of 4 LED lights together in Step 3.
(b) Connect the wire came with the IR Distance sensor leaving the loose wire end to be connected to the board.
(c) Solder the Piezoelectric Meter and associate resistors per Step 2
(2) 4x Piezoelectric Meters for detecting the pressure of the stamping, 1x Piezoelectric Meter for detecting air pressure of a blow, 2x IR Distance Sensors and 2 sets of 4 Neopixel LED light each to feedback stamp is detected are all soldered to one Arduino Micro Board while the RFID reader is connected to the same board via USB cable. Place all components like the pictures and schematic below. You can make the board as small as possible. Place all components like the pictures below. You can make the board as small as possible.
(3) RE the order of soldering, we recommend to solder the Piezoelectric Meters to detect the pressure of stamping first at the four corners of the Printed Circuit Board.
(4) Secondly, the RFID Reader USB receiver first to the Printed Circuit Board. RFID Reader's USB has 4 connectors. RX of the USB needs to connect to Arduino's TX while TX of the USB needs to connect to Arduino's RX. The other 2 connectors of the USB needs to connect to VCC and GRD of the Arduino. If your Reader is not reading anything after soldering, you may have the TX and RX reversed or connected wrong.
(5) Then the rest in no particular order. Please reference the length of the wire when you solder. As you can see in the box assembly video, the wire is long because the sensors and LED light would need to run along the box in specific locations so the length is necessary.
STEP 5: Step 5: Program RFID Tag
If you choose to buy the reader from another vendor, make sure it comes with a manual. You will need the manual for instruction to write the code to activate the RFID tags specific to the reader so it can be read by the reader automatically when placed onto the reader.
Record the unique identification number of each RFID tag that will be placed to each stamp corresponding to each alphabet. In the Processing code, replace your set of RFID tag ID numbers.
STEP 6: Step 6: Code Receiving and Sending Sensors Data From Arduino to Processing
Connect your Arduino Boards to the Computer and run the Arduino and Processing files below. You may need to test the range and sensitivity of the sensors you purchased and adjust the code accordingly to optimize the text display quality.
Processing File: final_processing.zip
Arduino Files: final_2.zip
Including the following
- Piezoelectric Pressure Meter
- IR Distance Sensor
- RFID Sensor LED
STEP 7: Step 7: Making the Display and Input Box
(1) The Display and Input Box is laser cut from 3mm MDF. You can use other material that can be laser cut as well such as acrylic. AI files used can be found below. You should result in the following pieces.
(2) The 2 side pieces are painted in black as shown in picture below. Left is before painting while right image is after.
(3) We ran out of paint. Therefore, we stick a piece of black sway cloth to 6 pieces of MDF. We also added 2 pieces of sway that we painted as we found the sway is not as reflective as paint providing better display result.
(4) On the side of the MDF touching the iPad that is not painted/covered by sway, stick 2 pieces of wood with wood glue as shown in picture to hold the iPad Mini in place.
Display & Input Box ai File: box.ai
Acrylic ai File: semi-reflective.ai
STEP 8: Step 8: Making the Stamps
We have made 30 stamps including 26 alphabets and 4 symbols. The stamps and the box are laser cut from 3mm MDF. We would recommend 2mm MDF so the stamp is not as big proportional to the RFID reader but we don't have 2 mm MDF available so that's what we used. You can use other material that can be laser cut as well such as acrylic. AI files used can be found below.
The following video illustrated how the stamp is assembled:
We designed a compartment on the stamping end of the stamp as close to the RFID reader as possible. The stamp used joinery design, hence, thinner than 3mm MDF would be less bulky. Use wood glue to glue the edges that are loose after you've programmed the RFID tags. Test your RFID tag and reader sensitivity. The Reader cannot read the smaller tag (i.e. 1mm diameter) with smaller antenna if there's anything in between them thicker than 1mm in our experience. Test them before you proceed with building the stamps.
The box hold all the stamps in one place.
Stamps ai File:stamp8c_2cm_cc.ai
Stamp Box ai File: Stamp_box6_cc.ai
STEP 9: Step 9: Assembling Input & Display Box
(1) The assembly of the display and input box is shown in the video below:
(2) Below specify additional details already shown in the video to add clarity. The triangle is placed within the box as shown in the picture below (picture below shown in wood colour to show in picture. It should be covered by black sway) to hold the 2 pieces of acrylic. Make sure the position of the 2 triangle opposite to each other are aligned.
(3) The opening on the top is to fit the RFID Reader. There is an opening on one side for the box for the USB cable. The four Piezoelectric Sensors to be secured at the bottom of the interior of the Input box as image below.
(4) Place a piece of bubble wrap or black sway between the Piezoelectric sensor and the RFID Reader to give some cushion to the Piezoelectric Meters to protect them.
(5) Place a piece of MDF same size as the RFID Reader between the bubble wrap / sway and the RFID Reader.
(6) Finally, place the top piece with the RFID Reader opening to the top. Place a piece of MDF same size to the Reader to the opening to hid the Reader.
(7) Attached the IR Distance Sensor and LED lights to the side pieces of the display box. Repeat for left and right side following the image below.
(8) Place the iPad Mini to the compartment indicated below. The USB cable connecting the computer and iPad should run following the video so the box can be closed.
(9) Finally, place the side pieces to cover the iPad Mini and internal wiring as follow.
7 Comments
MyxomopoBHeT. 8 years ago
What is the meaning of this unit?
jleungf 8 years ago
We are trying out translating something physical and tangible into digital and intangible vice versa. Words stamped can be manipulated because it became digitally displayed. We tried out only hand gesture to change text sizes and blow to erase words but there are so much more manipulation possible can try out in the future.
Little is understood, even with a translator :)
Maybe you make a video ?!
jleungf 8 years ago
Thanks for letting me know. I've uploaded 11 steps and a video of how it works but it didn't get uploaded. Will upload the rest that are missing.
I just found this video. It's funny!
Nothing is lost, everything is in place :)
DIY Hacks and How Tos 8 years ago
Cool display
jleungf 8 years ago
Glad you like it!
