Introduction: Airsoft Goggle Less Fog Mod
This mod is for airosft goggles that have foam around the plastic, and can help reduce, eliminate the fog up of your goggles. The basics of this mod are improving airflow in your goggles, your goggles can fog up as a result of breathing fast or bad air flow. This is a very easy mod, the only requirement is to remove the foam on the sides. You could remove all of the foam, but the foam also makes for better protection and durability.
Warning: I am not responsible for any damage to your goggles, use this at your own risk. The mod is very safe, but there may be things that I'm not aware of, and I'm not responsible for your actions.
Step 1: Mod for Foam Goggles
Start by removing the foam around the sides of the goggles, no tools are required since the material is very breakable. Once the plastic with the holes is exposed, your ready to play.
Step 2: Done!
Once the foam is removed, you can use them. Another mod which I will be showing you guys how to make in the future is putting a cooling fan inside of your goggles for the best airflow and cooling.
