Introduction: Airsoft Targeting
Step 1: Aligning Your Gun Sight
Now there are alot of scopes out there so I will be telling you 1 way of tuning them.
Learn how to properly boresight a gun in order to mount it correctly. Boresighting involves using both the barrel (or bore) of the rifle and the rifle scope to focus on a nearby fixed object. By alternating your viewpoint between the two lines of sight, you will be able to adjust the scope until the viewpoint is the same. Ensure that the gun does not move during this process, however, or the alignment will be wrong.
Fire a few practice rounds, if you are able, to see how closely the boresighting process aligned the rifle scope. Try to shoot in a tightly focused pattern, which will immediately tell you how accurate your sights are.
Make more fine-tuned adjustments on your scope by adjusting the alignment wheels on your scope. On most scopes, one knob will control the horizontal alignment of the rifle scope, and the other will adjust the scope on the vertical plane. Depending upon the scope, each click of the knob will result in an adjustment that is either 1/4 or 1/2 of an inch.
Become comfortable with operating the focus knob, so that you will be able to make quick and fluid adjustments when you are out hunting in the field. While many modern scopes feature an automatic or speed focus feature that does the work for you, you will still need to familiarize yourself with how quickly they work so you will be able to time your shots more efficiently.
Know how to use the crosshairs of the scope to become more accurate with your shots. Many modern scopes use crosshairs that can help you estimate bullet drop and wind direction, and some even offer illuminated bulls eyes or laser guides to increase your skills even further.
Step 2: Using Your Pistol Sight
there are many different sights so this step is on pistols if you have a rifle then go to part 3.
this is the type of pistol i have the p9 stinger. Now to sight you look down the top of the gun through the part on the back and align it with the part on the front it should form a perfect rectangle now aim your front sight at your target then align it with your back sight and your ready to fire.
Step 3: Using Your Rifle Sight
Thank you plese comment rate and subscribe.!
