Introduction: Alcohol Torch W/ Household Items
My goal for this torch was to keep the cost less than 5 bucks. You will most likely have all the supplies. Even though it is very cheap, it burns for around 10 minutes and is hard to put out( I had to use a garden hose). Also it burns fairly hot and bright.
Step 1: Materials
For this torch you will need:
-rubbing alcohol
-cotton balls
-wire(aprox. 3 ft.)
- cotton rag(roughly 15"x10")
-a stick(roughly 2 ft.)
-rubbing alcohol
-cotton balls
-wire(aprox. 3 ft.)
Step 2: Lining the Cotton Balls
Line three or four cotton balls on each side of the stick.
Step 3: Wrapping the Cotton Balls
Wrap the rag very tightly around the cotton balls. Once finished, wrap the entire thing(excluding handle), in wire.
Step 4: Finishing the Torch
Trim the excess wire then pour the alcohol onto it(or saturate it). Once it is wet enough, soaked but not dripping, all you have to do is light it!
