Introduction: Alex's Surfboard Repair Tips--fixing a Delamination/split Fiberglass
So, I just got a couple of beat-up surfboards off craigslist and I've been fixing them up this past week. Naturally, I've been documenting everything, so this is the first in what'll hopefully be a quick, punchy series of quick tips for fixing various surfboard ailments.
This particular instructable will show you how to fix a nasty delamination/split. One of the fins of my new [sic] surfboard must have gotten whacked at some point, since the fiberglass had actually cracked open and had some uberdelamination going on. After five minutes of work and some drying time, it was good as new!
enjoy!
--alex
www.artiswrong.com
Step 1: What's Wrong?
Well, here the main problem is that the fiberglass actually broke off. That fin's not long for this world. It either needs some tender love and care or a quick mercy slaying. Being a humanitarian type, I opted for the tender lovin' route.
The other problem is that the fiberglass is delaminating, or separating from the foam core. Even if I were to re-attach the fiberglass, it still wouldn't have much rigidity, since a couple layers of fiberglass alone isn't very strong. You have to glue it to something to really take advantage of the modern marvel that is composite construction
Step 2: Get Da Tools
First off, put up some music. I found that the white stripes album Icky Thump, followed by the track Ivanka by Imperial Teen looped until I got sick of it. If you're unsure of what music to listen to, I've helpfully posted a new mix to my site.
Next, go to your local surf shop and get yourself some epoxy. I really recommend the surf shop, since some epoxies will tear through foam like crap through a goose, and your local surf experts will know what epoxy is appropriate for you. You'll also need some fiberglass cloth (you can get it at a surf shop or any hardware store), some disposable gloves. a couple C-clamps, some scrap wood and a little tupperware to mix the epoxy in.
Step 3: Fix the Delamination
So, this is a mondo delaminatio. In a way, it's kinda good, since it means it's simpler to get the epoxy back under the fiberglass. If you're just fixing a closed off bubble in your board, you have to inject the epoxy in with a syringe. Here we can just smear it under.
First off, tear off a bit of sandpaper and slide it under the delamination. Rasp it all around and get rid of any burrs in the foam or the fiberglass.
Next, mix up some of your epoxy. Mix it really well--I usually mix it for a minute straight. Popsicle sticks are great for mixing, or you can do what I do and just use a piece of cardboard. Get a thin piece of cardboard or over thin, stiff material gooped up with epoxy and slide it under the fiberglass. Move it all around in there. If you press on the fiberglass, you should be able to see where the epoxy is through the glass. Keep adding epoxy until you have the entire area covered. Make sure there's no bubbles under there.
Step 4: The Clamps!
OK, so now you want to clamp the fiberglass firmly to the foam while the epoxy dries. What's important here is that you don't clamp directly to the board--that's a good way to dent up your board, and it also doesn't distribute even force across the area you're gluing. Instead, cut some small wooden blocks and put them between the clamp jaws and the board on either side of the surfboard. Tighten the clamp down until epoxy smushes out.
Keep it clamped down and let it dry overnight. While you're waiting listen to some Handsome Boy Modeling School. Oh, Nathaniel Merriweather! You rogue!
(you might notice that there's no fin in the picture for this step. I didn't take a picture of fixing this particular delamination, but here I'm fixing another similar delamination on the same surfboard.
Step 5: Eyes Glassing Over
OK, so you come back the next day and everything's dry. You should be able to grab the fin and put a bunch of force on it without it moving. Isn't epoxy great? If it moves, it means you don't have a good bond between your epoxy and the foam and you should sand it up and do it again.
Now, you're gonna put a piece of fiberglass over the crack to patch it up. Take your fiberglass cloth and some scissors you're not too attached to and cut up a patch that'll fit over the crack with maybe an inch of extra on all sides.
Now, either with an electric sander (a palm sander, not a belt sander) or just some good old-fashioned sandpaper and elbow grease, smooth out the area around the crack. Fiberglass sticks really well to really smooth surfaces, and it loses lots of strength any time it loses contact with whatever's under it.
Once you're happy with your sandjob, lay the fiberglass over the crack and mix up some epoxy. Dribble a little bit on top of the fiberglass and then using a piece of cardboard, spread the epoxy out over the fiberglass. When the fiberglass is 'wet', it should be see-through. You don't want to drench the thing in epoxy, but make sure you get the entire piece wet, and then squeejee off any excess.
Cool. Let it dry and come back the next day.
Step 6: Done!
Sweet! You should be done, and you now have in your possession a lovely repaired board that's well stuck to the board and the glass around it. You might want to sand it down a bit to smooth it out, but it should be pretty smooth as is. Get out there and catch some waves!
--alex
www.artiswrong.com
7 Comments
7 years ago on Introduction
11 years ago on Step 4
This looks like my 30 year old Surf Board! I've been wanting to fix it up.
14 years ago on Introduction
I like your repair. I would like to invite you to join my new group 'Remarkable Repairs' https://www.instructables.com/group/repair/
And was wondering if you would like to join the Most Remarkable Repair Contest Platform21 organises with Dutch magazine Bright. Platform21 is a design platform in Amsterdam and our current project is called Platform21 = Repairing. We hope to spur a reappraisal of repair, which is a kind of forgotten activity in our throwaway society. Please check http://www.platform21.nl/page/4509/en for more. I hope to welcome you as a contestant!
14 years ago on Step 2
i was wondering does the Pc 11 epoxy works all right or could you tell me wich epoxy you used cuz in my place there aint no surfshops
15 years ago on Introduction
Nice. I'm just about to drill some holes in a 11' soft-top. My plan is to insert some windsurfing footstrap plugs along each side so I can attach nylon webbing for my little girls to hold on to while I'm behind them. I got the idea from watching the kids playing around with a rescue surfboard that has handles all along the sides.
Reply 15 years ago on Introduction
Cool! I have no idea how to do that--I'm pretty much just making it up as I go along. You should post an instructable when you do it
cool, i might show this to my friend.
