Introduction: Alien Spacecraft
I will be showing you how to make a diamond shaped spacecraft with an antenna on Tinkercad
Step 1: The Body
  1. Add a diamond
  2. Make it your desired size (bigger size is recommended)
  3. Float your diamond slightly off the ground
Step 2: Add Leg
  1. Add a cylinder
  2. Shrink the width of the cylinder
  3. Attach the cylinder to the side of the diamond
Step 3: Add Foot
  1. Add a half sphere
  2. Flatten the half sphere slightly
  3. Rotate the half sphere so the flat face connects to the bottom of the cylinder
  4. Make sure that the rounded part of the sphere is touching the ground
Step 4: Duplicate
  1. Duplicate the already placed cylinder and place it slightly behind the first
  2. Duplicate the half circle and connect the flat face to the second similar
  3. Then duplicate the cylinder twice and place it on the other side of the diamond opposite to the first two
  4. Duplicate the half circle two more times and connect it two the two new cylinders
Step 5: Antenna
  1. Add a cone
  2. stretch the cone to make it around double the original height
  3. Then place the cone on top of the diamond
  4. Then slightly sink the cone into the diamond so that the wide base is not showing
Step 6:
Enjoy the new ship
