Almost Free Camp Lantern Case
Intro: Almost Free Camp Lantern Case
Broken lantern glass?? Read on.....After a season of camping I decided I needed to address the lantern situation....a little too late by the looks of it. Not wanting to spend alot of money on a store bought item I figured I could build myself. So here is my attempt at a close to free, sturdy lantern case.
STEP 1: Find a Few Coffee Tins
I have a problem throwing away possibly useful things. Coffe tins is one.
If you have a pile as I do, find a matching pair.
STEP 2: A Little Trim
The first step was to make two into one. After looking a little I decided to take my can opener and cut the upper lip off of one can
STEP 3: Cut to Length
As I wanted the most compact unit possible I cut one can to length. This will be the upper tin so I left the upper lip intact to keep a little rigidity in the can.
Cut this with whatever means you have at hand. Be aware this will leave VERY sharp edges. Sand, file , grind all burs off of the cut edge.
STEP 4: Make 2 Into 1
Now at this point was a test fit. A little playing around I was able to mate the bottom tin and top tin using the factory ridges. They did fit quite snug. The only downside I have seen so far is that I have to remove the handle from lantern and slide both in together to make it fit. I can live with that.....
STEP 5: Glue Pieces Together
I added a strong super glue to the top can, lowest ridge. As the factory top edge sits outside of this indented ridge and create a factory look as well as a tight fit. I decided to line up the vertical seam to make it look a little better. Not at all needed, but I didn it anyway.
STEP 6: Add a Handle and Grommets
Now I decided to add a simple handle. I have a bunch of grommets kicking around so to finish the holes and maybe add a little nicer finished look I added those as well.
Pretty straight forward. Drill hole, insert grommets and use tool to set them. If you are to paint add grommets after for a nicer finished look.
This handle is a piece of aluminum welding wire. Any sturdy wire would work just fine.
I hope this inspires!!!
3 Comments
GnomadDan 8 years ago
Great job!
I have a more compact lantern, the Coleman 5133.
It fits nicely in one of those tall narrow spaghetti sauce cans.
No need to cut, it sticks out of the top a little and I dont need to remove the wire handle
redweaver 8 years ago
cutprogram1 8 years ago
