Introduction: Alternative Generation Worksheet
This step by step process will help you create an Alternative Generations Worksheet, save it and print it.
Step 1: Disclaimer
This presentation is only for educational use only, it is
not intended to take one’s professional position. Samples used are able to be changed and do not have to be used in the same format every time. This is a safe example and no one was harmed in the making.
Step 2: Turn on Your Computer
This button could be on the side or on the very front
Step 3: Open Excel
Once your computer has loaded and is ready locate excel on the screen and double click to open
Step 4: Select Blank Worksheet
Once Excel has opened select the first option that is called Blank Worksheet
Step 5: Worksheet Will Open
After selecting blank worksheet the excel program will open up a blank worksheet that will look like this
Step 6: Insert Column Titles
Starting in Cell B1 start to type in the Column titles
· Alternative
· Description
· Author
· Contact Information (phone/e-mail)
· Sources or additional information
Step 7: Inserting Numbers
In cell B2 type the numbers 1-20 hitting the enter key to go down each row
Step 8: Fitting the Words in the Cell
To fit all the words in the column go to the line between each cell and double click that line
This automatically moves the cell so that each word will fit
Step 9: Print Lines
Locate the page layout tab
Once you have clicked on it select the print gridlines option
Step 10: Start to Save the File
Once you finished resizing the cells to fit the words
Go to the top right hand of the worksheet to the tab that says FILE
Step 11: Save As
When you select the tab file this new page appears
That is where you go down the tabs and select save as
Step 12: Opening Save As
When you select the tab Save As this new screen will appear
This is where you will name your file so that you can locate it to reprint it if needed again
Step 13: Finish Saving
Once you finished adding the title you can hit your ENTER key or go to the right hand side and hit that save button beside the new document title
Step 14: Now to Print
Once the file is saved it will take you back to your worksheet automatically
You will want to go to the File tab again or hit Crtl and the letter p at the same time
Step 15: Find the Print Tab
When you find the print tab click that and this page will open up
Step 16: Fit Sheet to One Page
Before selecting print check on your page options to the last one
Make sure that Fit sheet to one page is selected
Step 17: Print
Be sure your computer is connected
Hit that print button!
