Introduction: Altoid Flux Capacitor Computer Lamp
This is a project I made because I am a big fan of back to the future and I love making stuff with hot glue and altoid cans
I had the idea because I was trying to build a full size flux capacitor replica and when I finished it I wished I had done it more accurately and to scale,
So I started looking for parts to build it with and in our barn I found an altoid can I also had some broken Christmas trees lights in our attic so I started making one
After starting it was harder than I thought it would be but when I was done it was definitely worth the effort.
Thank you for looking and I hope you enjoy it as much as I did!!!!!!!!
Step 1:
Step 2: Supplies
You will need
Altoid tin
Red wire
Yellow wire (slightly smaller than the red)
Christmas tree lights
Old android charger (make sure it is a cheap one or it won’t work)
Black duct tape
Aluminum foil or silver paint (paint would work better but I did not have any so I used foil)
Printer with paper
Small piece of clear plastic. You can get it from toy packaging .
Altoid tin
Red wire
Black duct tape
Printer with paper
Step 3: Preparing the Altoid Can
Please be very careful at this step
Using a dremel cut a hole. Be careful not to cut yourself.
Step 4: Installing First Two Lights
Take your two Christmas lights and glue them as shown.
Make sure to center them.
Step 5: Gluing Last Light
Take the last light make sure to leave plenty of wire on each side and glue it into place.
It should look like this.
Step 6: Adding the Wires
Cut the red wire into three .25 inch pieces and bend them. picture shown for scale.
Step 7: Adding Wires Pt2
Cut half inch pieces out of the yellow wire bend the tip and glue it to the red wires. make three.
Step 8: Adding the Wires Pt3
Glue the red and yellow wires as shown and close the door to make sure to make they can be seen.
Step 9: Wiring It for Real
This is the real wires for power to the lights
Cut a hole in the top of the altoid can
Cut off the end of the Android charger and feed the wire through the hole
Connect the wires as shown in the pictures you may need a jumper cable
Step 10: Test the Lights to Make Sure It Works
You may need a small piece of cardboard to insulate .
Step 11: Add Rubber for Safety
This step will be cover up later but you should still do this
Cut the duct tape and line the inside
Step 12: Adding the Window
Take a piece of clear plastic slightly bigger than the hole and glue it to the inside
I used a old salad container
Step 13: Adding the Foil (or Paint)
Cover the whole front with foil as shown I used hot glue to glue it and a lighter to smooth out the bumps
Step 14: Adding Second Rubber Layer
This is the rubber “Sealing” layer
Cut a piece of duct tape slightly longer and wider than the hole
Cover it with dust (if you don’t do this step the tape will never come apart )
Fold it in half lengthwise
Round the edges
Cut out the inside as shown
Glue to front of the flux capacitor
Round the edges
Step 15: Decal
Print out a picture of the flux capacitor. I used a wallpaper version because it had no background
Use the printer settings to shrink it to the size you want
Than cut out the ‘ disconnect Capacitor drive before opening’ and ‘ shield eyes from light‘ on the paper
Glue the disconnect sign on the front and the shield eyes a fifth of the way up the window
Step 16: Plug in and Enjoy
I would not plug into a computer unless you are sure it works without a problem
I plug mine into the wall to be safe
