Introduction: Altoids' Noise Maker
Step 1: Supplies
1 Altoids' tin
1 double AAA battery holder
1 switch with mounting bracket
1 noise maker of your choice
1 small wire nut
Silicone
Electrical tape (optional)
1 small wire nut
Silicone
Step 2:
First sorry that I don't have step by step pictures but I'll try my best to explain everything clearly.
Anyway first you are going to want to drill a hole in the middle of the side of the tin. When you drill the hole have the top closed and find the middle between the bottom and the bottom of the lid.
Next put in the switch.
After that complete the circuit by using a wire nut to connect the 2 red wires from the battery holder to the noise maker (I used electrical tape but you don't have to). Then connect both black wires to the switch which can be done using a soldering iron but it's not necessary.
