Introduction: Altoids Paracord Kit
There I was, I had just finished off the last Altoid in the tin. I had no idea what to do with it. I set it off to the side to work with my paracord, and it hit me. The Altoids Paracord Kit! Its a kit that has most everything you need to work with paracord. If you can think of anything else that could go into it, leave a comment, ill try to fit it in the tin.
Step 1: Contents
Here are the contents of the kit.
1. Lighter
2. Measuring Tape
3. Swiss Army Knife
4. Buckle
5. Key ring
6. Ball Bearing
7. Paracord Fid
8. Paracord
I will tell about the purpose for the contents in the following steps.
1. Lighter
2. Measuring Tape
3. Swiss Army Knife
4. Buckle
5. Key ring
6. Ball Bearing
7. Paracord Fid
8. Paracord
Step 2: Lighter
Meant for melting the paracord ends. A small Bic lighter will serve this purpose. Also, a windproof lighter about this size would be great.
Step 3: Measuring Tape
I put this in to measure paracord accurately, so as not to waste it. It won't be able to measure anything over 4 feet at once, but that ability has to be sacrificed so it can actually fit in the kit.
Step 4: Swiss Army Knife
I put this in for its knife and tweezers. The knife for cutting the paracord, and the tweezers for threading the paracord.
Step 5: Buckle, Key Ring, and Ball Bearing
The buckle is for bracelets, the key ring is for lanyards, and the ball bearing is for a monkeys fist.
Step 6: Paracord Fid
I put this in for more easy knot tying. I love turks head knots, and this makes tying them so much easier. Credit goes to MacGyver9 for the invention of these.
Step 7: Paracord
I added this in for two reasons: One, for something to tie knots with, and two, to fill up all extra space to prevent the rattling of other parts. There is no set length to put in, just as much as you can fit into the kit.
Step 8: Packing
This is how i would recommend fitting it all in. It will take some cramming, but it should all fit in. Its a great little kit to keep in your pocket if you love to work with paracord, like me. For bigger projects, say, a bracelet, you will need to have more paracord with the kit. Wrapping it around the kit is a great solution. Also, all questions will be answered, and improvements are greatly appreciated.
