Altoids Tin Portable Breadboard With Power Supply
Introduction: Altoids Tin Portable Breadboard With Power Supply
Im using solderless breadboard very often, I find it very useful you dont have to solder everything, so you will not destroy your parts and you can quickly change something if theres a problem. Recently I am working on one big project which contains few small projects first was the Altoids Tin Helping hands with fume extractor and heres the second project.
PARTS :
1x LM317
1x 120R rezistor
1x 760R rezistor
1x 330R rezistor
(or you can use you own values which you can calculate from the equation on the picture in the second step)
2x Switch
Some DC connector (depend on what supply you want to use, ive also used 9V battery to make it really protable)
Altoids Tin
Small solderless breadboard
optional = control LED
piece of protoboard to solder on
TOOLS :
Soldering iron
dremel (im using some fake chineese)
Step 1: Circuit
heres the circuit of the regulator ive putted it on piece of protoboard
while assembling keep on mind that you have to put it inside tin, so dont make it too big
then make leads from output and ground to the two rows on the breadboard (ive glued them)
Step 2: Assemble It
When youre done assemble everything if you are using optional battery meke inside some walls from junk piecces of plastic or something like that
Step 3: Optional : Make Some Jupers
well you can use basic cables but i hate them so ive decided to create my own
you will need :
- some sort of insulated wire
- insulating tube
- stripped legs of rezistors or pin headers
strip piece of wire than solder pin header on them and insulate them with tube
then you can store them inside the tin
Step 4: And Youre Done
when youre it should looks like this, you should probably measure voltege coming out with multimeter.
Here's video how it works  :
this was my second instructable im still learning how to make it right
if there any problem leave a comment or send a message
if you want to see more of my projects :
www.youtube.com/user/legwinskij
1 Person Made This Project!
  • Reuse Challenge
    Reuse Challenge
  • Rice & Grains Challenge
  • Metal Contest
    Metal Contest
13 Comments
bradk3
bradk3
9 years ago on Introduction
Great project! I made this and it has turned out to be one of the singularly most useful things in my workshop! Thanks for posting it!
legwinskij
legwinskij
Thanks :) I'm glad it is useful ! It could use some upgrages I think.
brassjammer
brassjammer
11 years ago on Step 4
This is an awesome project. Do you know exactly what the type or model number of that breadboard is? Its a perfect fit and I would like to find one just like it.
crf250rider14
crf250rider14
11 years ago on Introduction
Hey there, I just want to say what a great project you built! I just have one question, instead of having the output be in a breadboard could I put a ground, 9v, and 5v terminals on the case instead? Im sort of new to this and im also wondering what kind of things you would run on the breadboard.
Any help will be greatly appreaciated!
Thanks.
legwinskij
legwinskij
Reply 11 years ago on Introduction
Hi and thanks :)
Of course you can do that. You dont have to connect 9V and 5V to the breadboard you can instead connect it to some connector
crf250rider14
crf250rider14
Alright cool. But could you maybe take a few photos of the circuit that is inside the tin. Or maybe a little better explanation.
Thanks again.
legwinskij
legwinskij
Well as you can see circuit is made at prefboard and I understand that is hard to see connections but what specificly you dont understand ?
crf250rider14
crf250rider14
Like what goes where, how the wires and pieces are placed onto the board. I understand everything else about the project just do not understand how it is layed out.
Thanks again for the reply.
Oh and one more thing, I see you have a power adapter input on the side of the tin, what kind of adapter would I use? Like a wall wart?
legwinskij
legwinskij
Well I've used perfboard with paralelly connected pins (http://farm4.static.flickr.com/3262/2556867092_7e890a61a9.jpg right one)
one line is for + one for - and one for adjust. Yes you can use any wall wart you want up to 35V but then theres problem with overheating LM317
crf250rider14
crf250rider14
Hmm ok sounds good. One more question, could I use http://www.radioshack.com/product/index.jsp?productId=2102861 for my terminals?
Thanks again.
legwinskij
legwinskij
Yes of course you just have to solder two cabels coming out of the altiods tin (black and red) to these terminals
imakethings
imakethings
12 years ago on Introduction
Good packaging.. would be better if u add an led as an indicator any ways gr8 portability..
legwinskij
legwinskij
Reply 12 years ago on Introduction
well there is LED as indicator you can see it on the pictures and ive mentioned in the instructable that it is optional but thanks :)
