Introduction: Amazing Harry Potter Wands...:D
These wands are made entirely out of paper and they look awsome...:D
You need :
A4 Paper / US Letter Size (not both)
Hot glue gun
Double sided or two sides of celatape
Paint
They look UNBELIVABLY realistic....!!!:D
Please Try these you'll be so pleased...!! :D
Children under 10 May need a adults help..!!!!!! :)
This is not completly mine this is also someone elses so please understand that..!
Step 1: First Step....:D!
Firtly you need to place a peice of double sided sticky tape diagnally across a A4 piece of paper.
Make sure its diagonal..!!! 8)
Look below for the daigram!!!! 8)
Step 2: Step Two.....8)
Secondly role the paper tightly.
IMPORTANT: Please don't forget to remove the cover on the side of the tape.. i no it sounds silly but u'd be supprised...!!! :D
Step 3:
Once rolled up to the tape cover the rimainder of the paper in glue...:D
Continue To Roll....:D
Step 4: Step 4...!:)
Next,
Just snip a little be off of each end so its the same length
Diagram Below....:D
Step 5: Step 5..:D
Carefully dribble glue gun glue into both ends of the wand (one at a time, waiting till each end is set). For the bigger of the two ends, you can pack the end with a little rolled up tissue pushed down a bit with a pencil so that you don't have to use too much glue. For the bigger end you will probably need to have two goes. If you are careful you can achieve a rounded end, as the glue is setting make sure that you rotate the wand to stop it slumping to one side or dripping over the edge. The same goes for the little end, although if you have wound the wand tightly enough, you will not need to fill this twice.
Diagram Bellow....:)x
Step 6: Step 6 Nearly Dun...!! :)
Now make a preety pattern round the wand and turn it as you do so it goes all the way round dont forget 2 full cercles on bottom and a space for your hand...!!!!
see diagram bellow:D
Step 7: Step 7
Apply base this can be:
paint
hairspray
spray paint
or artist base...!
Apply this everywhere....!!!:D
See diagram below...:D!!
Step 8: Step 8 Painting
Paint your wand whatever colour you would like it !!!
I find these work best:
Brown
White
Lite brown
Burgandy
Black
Earthy colours even green dark tho...:D
Step 9: Step 9 Gold (Optional)
Now using either:
Thin paint brush and gold paint
Finger and Gold paint
Gold pen...:S
Use one of the above methods ^^^^^^^ and go round all the sticky out bits...:D
Diagram Below...!! :)
Step 10: Finishing Step:
Use your wand to impress your friends they'll never know that its paper:
Saves you money
Un brakeable
Fun
Get CASTING.......!!!!!!!!!!! :D
Even add little pencil toppers on the end if u want....!!1 :D
