Introduction: Amazing K'nex Gun
This Amazing K'nex gun shoots a rubber band almost 20ft!!! Gun has great accuracy and great body!!!!! Have fun making and shooting the gun!!!!! :):) I made an amazing K'nex gun that shoots rubber bands, I'm not joking!! I made it by using K'nex pieces. I found a similar gun online and that's what gave me the idea of this gun that is different from many other guns in this category. I made this at my house in my bedroom. I used to do K'nex all the time when I was younger. I learned that hard work really pays off. I am most proud of the trigger system in the gun( the most complicated part of the gun). What I would do differently would be making the gun look a little bit more like a gun and make the gun shoot the rubber band a little farther if possible!! :):)
Step 1: Step 1
Gather all pieces needed. Look at picture for help at gathering up all the pieces.
Step 2: Step 2
Connect pieces shone you should then have 2 identical pieces as shone in the picture.
Step 3: Step 3
Connect both identical pieces you made in step 2 with 4 white rods.
Step 4: Step 4
Both pieces should be identical.
Step 5: Step 5
Add the two smaller pieces to the larger pieces. So that it is one larger long piece.
Step 6: Step 6
Add two, short, green rods and two orange rectangle pieces. :):)
Step 7: Step 7
Add six more green rods, and 4 more red pieces.
Step 8: Step 8
Shove blue rod through both holes in the yellow piece and through the hole in the middle of the orange rectangle piece.
Step 9: Step 9
Snap grey pieces onto the blue rod like shone.
Step 10: Step 10
Shove blue rod through all three of the holes in the orange rectangle pieces like shone.
Step 11: Step 11
Snap tan piece onto blue rod going through all three orange pieces.
Step 12: Step 12
Snap both grey piece to blue rod going through the three orange pieces.
Step 13: Step 13
Rotate the white rod sticking out. Remove the little green rod that is connected to the orange rectangular piece. Rotate the white rod back. And wrap rubber band around like shone in the picture.
Step 14: Last and Final Step:):)
Stretch rubber band out along the top like shone. Make sure your gun looks like second picture on this step. If your gun doesn't match the picture your rubber band won't fire.
Step 15: How to Fire
Pull white rode toward you. The white rod is the trigger. This is what makes your gun fire. CAREFULLY fire your gun. Don't point gun at people or animals. Have FUN!!!!!:):):):):)
